Reset Polk Magnifi Mini
jaclbejaclbe Posts: 3
edited May 2017 in Troubleshooting
Hi all,
just teached my TV remote to do the basic operations of the Magnifi remote as well.
Unfortunately, this is not working well. When I turn on the power button my TV goes on and the Polk goes off. Is there a way to reset the Magnifi Mini or at least unlearn a remote?
Best Answer
Answers
  • KennethSwaugerKennethSwauger Moderator Posts: 6,465
    Hello,
    Usually on Polk's soundbars if you place the unit in the standby mode and touch the "learn" button for a couple of seconds it will delete and learned remote codes. If this doesn't let me know.
    Regards, Ken
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • To me he puts every time automatically after some time the settings of the bass back to zero. How can you get this fixed?
    Hello,
    Make sure the soundbar is not plugged into a switched AC outlet, the power needs to be constant.
    Ken
  • ennu185ennu185 Posts: 1
    Hello,
    Regards, Ken
    What, where is "learn " button ?
Howdy, Stranger!
