Oppo, why why why???
afterburntafterburnt Posts: 4,313
edited April 2017 in Going Digital
Question: Why does the sound level drop and tone change dramatically when I turn off the TV? I was playing files from a portable HDD connected to one of the rear USB ports with the TV turned on to show my ol lady how use the Oppo. I turned the TV off so she could use the media control app on her phone to select the music, no point in burning up the TV for just listening to music. I don't recall if this happened before because most of the time I am playing from the PC via USB not the portable HDD. The Oppo is connected to the P5 pre via analog, optical, and RCA digital (I dont think switching these connections make any diference in SQ when playing from the HDD so I can't tell how the Oppo is sending the signal to the P5, however is does change the SQ when playing a disc) The HDMI outs from the Oppo are connected one to the TV and the other to the AVR (which is not on). The TV should be out of the picture no? Can anyone venture a guess as to why this is happening?
Bruce
Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
Hello Kitty boombox
Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
Self Control is over rated.
Mr. Sharpe wrote: »
Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • afterburntafterburnt Posts: 4,313
    I would have dicked around with pulling cables to figure it out but I had to go to work.
    Hello Kitty boombox
    Mr. Sharpe wrote: »
  • txcoastal1txcoastal1 Posts: 9,484
    I'm going to assume that there is a current drop when possibly when you turn the TV off
    2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures, Simaudio 780D DAC
    Gear on standby: Melody 101 tube pre, Modwright LS100, Unison Research Simply Italy Integrated
    Gone to new homes: (Matt Polk's)Threshold Stasis SA12e monoblocks, Pass XA30.5 amp, Usher MD2 speakers, Dynaudio C4 platinum speakers
    edited April 2017
    txcoastal1 wrote: »
    Ron, dont ya think that it would be the opposite?
    I cycled through the inputs on the P5 really quick and noticed no difference in SQ with the TV on and there is usually a marked difference between analog and digital. I will have to listen closer when I get home. But it sure is weird that the only cnnection between the Oppo and the TV is HDMI how the hell does that make a difference? My memory is shot and it has been a while but I dont think that it was doing this before, I probably would have remembered the volume dropping by half.
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    AH HA! nevermind.
    Hello Kitty boombox
    Mr. Sharpe wrote: »
  • EmlynEmlyn Posts: 2,030
    What was the solution? Something to do with Oppo's control app?
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Toshiba HD-DVD Player; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 Preamp; Sonic Frontiers Power 2 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Pioneer Elite SC97 receiver; Oppo 203; Squeezebox Touch; MIT S3 cables
  • Mikey081057Mikey081057 Posts: 5,075
    edited April 2017
    my guess is oppo's level adjustment from the setup menu
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7702 | Sunfire TGA-7401 | Oppo BDP-103D | Sony PS4 | Directv Genie HD DVR | Samsung 64" Plasma | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A23 x2 Amps Parsound Halo A21 Amp & P5 Pre | Marantz SR5011 AVR | Usher Dancer Mini-x DMD's| Usher BE-616 Center|KEF T100 Surrounds | SVS SB2000 Sub |Oppo UDP 203 | MIT Shotgun S3's | Marantz SA8004 SACD | Bluesound Node 2 | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | HP Elite Slice PC |Samsung 50" SUHD TV
    Patio Polk Atrium 8's |Marantz 2252B |
    Office Bluesound Node | Audioengine P4 | Peachtree Nova 125SE |
    Closet | SDA SRS 2.3's | Monitor 5B's Yamaha M80 | Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2385
    On mine the choices are fixed or variable. I think the variable setting allows controlling volume through the analog outputs from the remote's volume buttons. But I only use the HDMI outputs in the current system.
    afterburnt wrote: »
    AH HA! nevermind.
    He took his meds???
    Just messing with you bruce what was the best medicine
  • msgmsg Posts: 3,941
    afterburnt wrote: »
    AH HA! nevermind.
    Hahaha, Bruce, you're one of my favorites, man.
Howdy, Stranger!
