Polk audio monitor 60 series II
I have a set of these speakers. One day one of the two speaker lost much of sound. What I mean by that is the volume is extremely low compared to the other speaker. Balance on the receiver is the same. I switched the two speakers and the bad one is still very low in volume so it's not the receiver or wiring issue. Speaker cones doesn't look like they were blown or torn. Could you please provide some possibilities of what may be wrong with it? Someone may have turned the volume too loud causing this ?
Can you get us a pic of the crossovers2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Perhaps a blown tweeter? Carefully Unscrew the bad tweeter, and with the receiver connect the two terminals directly to the speaker wire. Turn on receiver and Slowly turn up the volume. If there is not sound, then that is your problem.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer
