Mahogany Finish
I am working on a project and will probably use kiln dried Mahogany 1x4's.
What is the best way to finish?
Urethane, oil, other?
1KVA Dreadnought
Marantz SA 8005
Sony PS4
Best Answers
    F1nut Posts: 49,782
    Answer ✓
    Are you wanting add color?
    Ok so, no spray equipment. An oil finish is easy, but doesn't build and offers extremely little protection. A wiping poly is just as easy, builds a little (is a film finish) and offers much greater protection.
  • machone
    machone Posts: 1,471
    Answer ✓
    No color.
    I think the wipe poly is the ticket.
    Thanks F1
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    Answer ✓
    Only one way to find out.
    Build it B)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
Answers
    F1nut Posts: 49,782
    There is no best way. It depends on the look you want, your skill set and the available equipment.
  • machone
    Durable satin finish.
    Sanding blocks, palm sander, steel wool.
    Some experience and mostly sane. :)
    It's going to be the legs supporting a mobile acoustic panel.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    No color.
    Thanks F1
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    F1nut Posts: 49,782
    Great, I hope it turns out the way you want.
  • machone
    I don't understand this question/answer stuff. Keeps asking yes/no and everything is out of order. :#
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    F1nut Posts: 49,782
    It's the disaster known as Vanilla.
  • Mikey081057
    Mikey081057 Posts: 7,127
    LOL Jesse is suggesting a poly wanna wipe vanilla solution
    Garage | Polk Monitor 5B's
