Tidal, oh won't somebody hep me please!?
Hello folks, resident more on here. Got some questions for all you pros. First: are Tidal playlist supposed to sync across platforms, I tried to add stuff from my pc and thought they would show up on my Oppo?
Second: Tidal "Masters" the MQ somethings, how can you tell which is which? For instance Larry Carlton shows a bunch of duplicate album covers. I am assuming that one is red book and the other is MQXYZ. How do you tell? I am not having as much fun as I deserve because I cant think my way out of my own way. My free trial is gonna run out before I figure this out. HEP!
    txcoastal1 Posts: 13,132
    Are you logging into Tidal via website or have you downloaded the PC app
  • Mikey081057
    Mikey081057 Posts: 7,127
    MQA should give you an indicator on your players user interface. They MQA stuff is listed under "MASTERS". Is your subscription "HIFI"? (The $20 one). Do you see the MASTERS on the Tidal/Auralic UI?
    Garage | Polk Monitor 5B's
    edited April 2017
    Just an example...PC app
    Type in Tutu under albums left side there will be a capital "M" = masters
  • Mikey081057
    You can see multiples of the same album without any of them being MASTERS
    If it with the Oppo, I can't help
    I only know my PC and my Simaudio DAC
  • afterburnt
    afterburnt Posts: 7,892
    I'll be damned, just did Carlton on the pc and no duplicates now wtf? However I do see the "M" when I search Tutu.
    How about the cross-platform playlist, is there a save or something? Ya would kindda think since it's one account it would show on the other device no? I am using the Android app for the Oppo and searching stuff on the pc.
    Make sure you have downloaded and using an app on pc, if you are just logged in via website you will not see masters
    I can see my playlists under "my music" across my iPhone, iPad, pc, and my simaudio
  • afterburnt
    Thanks Ron, I didn't even try the iPud yet. Lemme try that
    Bruce do u have the app icon on your PC
  • afterburnt
    Ok, I just got the app on the pc and it shows the "M" but the Assdroid app for Oppo does not lol. Anyway I will see what it looks like on the iPud tomorrow. Hey this may drive me back from crazy! Always put a positive spin right?
  • afterburnt
    txcoastal1 wrote: »
    Wow how did I miss that? Nice record!
  • afterburnt
    can't sleep iPud don't show it neither
  • WagnerRC
    WagnerRC Posts: 2,139
    MQA is awesome. Bravo Tidal.
  • afterburnt
    Any tips from anyone running Lightning DS?
  • Nightfall
    Nightfall Posts: 10,071
    I have an entire section specifically for masters on mine.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • WagnerRC
    edited April 2017
    Nightfall wrote: »
    same. here. on my iphone I open the tidal app in the ds program and chose the master tab. When the song is playing it shows the mqa.
  • afterburnt
    Grassyass I will try that when. I get home
  • voltz
    voltz Posts: 5,384
    edited April 2017
    When I use TIDAL on my Lightning DS app on the MINI, I see a MASTER list as a choice off to the left where it also says: Top 20 or Exclusive etc... but I do have the full premium that I got for 1 year free.
    and when I play one of the master files - below the LP art work it will say normally 48hz / 24 bit ....the standard music files will say 44hz/16 bit.
    Tha is if you click on the art work at lower left corner - then it will show wither it was 24 bit or 16bit
    Darryl
  • afterburnt
    What does the "E" mean?
  • vcwatkins
    vcwatkins Posts: 1,993
    afterburnt wrote: »
    If you are asking about an album label in Tidal, "Explicit".
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • afterburnt
    There is an "E" on some albums where the "M" for masters would appear. I don't think... that anything I was looking for was explicit.
  • afterburnt
    Has anyone gotten interference sort of
    like hearing the other tracks on an an 8 track while playing Tidal?
  • voltz
    voltz Posts: 5,384
    not thru my mini/Dac I haven't. as I been super happy with this combo!
  • afterburnt
    Could have just been the banshees in my head?
    treitz3 Posts: 18,334
    When I first used Tidal on my buddy's system down in Atlanta, I thought the user interface was easy and that the learning curve was zero. Today and on my rig? I bang my head often. The I-Pad is a royal PIA and finding the MQA (which should be easy) is a hit or miss.
    My devices do seem to sync up but to date, I still can't even log onto Tidal with my phone (not an I-phone or Andriod) using a 3rd party app. It keeps kicking me out saying my passwords are not correct.....even after I changed them...again....and again.
    Customer support with the Node sucks donkey d*(k and their forum doesn't offer any solution to what issues I am experiencing......and here I though this was to be a format of convenience. Boy was I wrong on that assumption.
    The desktop app seems to work best for me, the I-pad is a joke and the phone is useless. Good luck is all I can say.
    Oh, on the desktop app, it will list down at the bottom lower right hand corner whether or not the song you are playing is in CD form or MDQ. I have no clue what I'm playing on the I-POS.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Tidal through my Aries mini -> bryston bda3 has been flawless. I finally found the masters section, turns out I had about 50 search windows open in lightning DS. I'm loving this setup, I haven't touched vinyl or cds in about 2 weeks :frowning:
    2 channel:
    Theater:
  • afterburnt
    Mikey I really like it too. I was listening to someone Master and heard what I thought was interference but my ol lady said it was like talking on the recording.
  • kharp1
    kharp1 Posts: 3,453
    Some good info here, thanks all. I'm probably going to bite the bullet and pick up one of the Aurelics. Skip has alluded that there may be Android app on the way. That would be a plus. I miss the simplicity of streaming when I'm working around the house.
  • afterburnt
    Kharp the Auralic mini is a great piece of kit you are gonna love it
