Has anyone tried iFi Audio iSilencer 3.0 - USB Noise Filter by IFI?
I was thinking about an AudioQuest - Jitterbug USB Filter and saw this. Something to try along with my New USB cable
Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
Hello Kitty boombox
Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
Self Control is over rated.
Mr. Sharpe wrote: »
Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • DSkipDSkip Posts: 14,511
    edited April 2017
    Audioquest basically copied the original design when they made the jitter bug. I haven't heard this one, but they do change the sound. Personally, I'm more of an advocate of using that extra money to get a better cable instead. I think the gains are more profound on that front than what these dongles bring.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • afterburntafterburnt Posts: 4,389
    Ok thanks, I go for the cable. What HDD and cable do you use?
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    I don't use an external for music. I have a Starlight 7 and a Platinum Starlight 7.
    audiothesis.com/
    Cabling: Wireworld
    So what is your source? Bare with me, I am trying to learn. Everyone says that I will never learn but that won't stop me from beating my head against a brick wall....
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    Mostly tidal right now. If I do local, I stream from computers on my network. My best advice would be to hook that external up to a computer or your router and stream instead of a physical connection.
    audiothesis.com/
    Cabling: Wireworld
    edited April 2017
    Really? I am surprised to hear that. I was thinking that there would be a lot of noise from the pc
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    I'm not saying hook the computer to the rig. Use it as a storage device and stream from the computer using upnp etc.
    audiothesis.com/
    Cabling: Wireworld
    I have heard for instance that my P5 doesn't have and display because it would introduce more noise into the signal. I figured there was a lot more of that possibility with a computer. Anyway I have been using the HDD instead of DNLA for a long time because the SQ with the Oppo is so much better from the HDD than the PC. Thus my quest for a decent USB cable.
    Hello Kitty boombox
    Mr. Sharpe wrote: »
Howdy, Stranger!
