Definitive Technology BP2000 - Fortress hand wired crossovers, dynamat subwoofers, american beast
VR3
For your consideration is a pair of American made! Definitive Technology BP2000. This is a 120 pound, 50” tall behemoth, packed with FOUR 6.5” midbass drivers, TWO 1” aluminum dome tweeters, ONE 15” 300 watt amplified subwoofer all housed in a mirror image, nuclear bunker quality enclosure. Each enclosure wall with drivers features 1” thick medite panels, ¾” everywhere else, and high gloss black tops that are borderline right off the show room.
This is a speaker meant to get down and dirty, movies, gaming, music, fill up your house, don’t need an external subwoofer, solid extension to 23hz monster. The top end is very similar to the BP7000 (according to Chet Pelowski of Sound United) and the bass is a nice sealed enclosure with tactile response and good extension when setup properly!
The crossovers have been modified to the latest version featuring top tier parts from Clarity Cap, Jantzen and Mundorf.
The parts layout for the crossover is as follows –
Tweeter network –
Clarity Cap CSA/ESA
Mundorf Mox Resistors
Jantzen Inductors
Midbass Network –
Clarity Cap CSA/ESA
Mundorf E-Cap bypassed by Clarity Cap ESA
Jantzen Permite Core Inductors
Hand wired on a lexan substrate, isolated from the enclosure wall
The subwoofer basket has been lined with dynamat. The enclosure walls are lined with sonopure foam from the factory.
They fill up the house with sound, they will not need external subwoofers for most users. The staging is nice, tight and fills up a large room. You will not be disappointed in a multi-use system! They were not designed for strict 2 channel systems, they sound great for music but these are hungry for power, throw out a wide stage, great for off axis, home theater, games, occasional intimate listening.
Dimmensions: 50"H, 9"W, 16 7/8 /8 "D
Weight: 120 lbs each
Frequency Response: 15Hz - 30kHz (-10db)
Efficiency: 90 dB
Impedance: Compatible with 4-8 ohm outputs
Built-in Subwoofer Amplifier: 300 watts RMS
Tweeters: Two 1" (25 mm) aluminum dome tweeter (one in the front and one in the back)
Midrange: Four 6 ½" (17 cm) high definition cast-magnesium basket polymer drivers (two on the front and two on the back)
Subwoofer: One 15" (38.1 cm) subwoofer on the side
The socks are in excellent condition, no snags, tears, holes that I can note. The tops are in fantastic condition, no notable scratches, dings, dents, etc. The bottom caps are in excellent condition, some small marks you probably would not notice in person. I am the second owner and I intended to keep them until I found a deal I could not pass up on a different set. I will be listing them publicly for $1,300 a pair + shipping. There is a pair listed, not modified, similar condition for $1,150.
Club Polk price is $1,000. I will be willing to drive up to 350 miles each way for a total of $180.00
Pictures
Videos
https://www.youtube.com/watch?v=7x5PaQnmkUM
https://www.youtube.com/watch?v=CARXlPp3zBI
Tweeter network –
Clarity Cap CSA/ESA
Jantzen Inductors
Midbass Network –
Clarity Cap CSA/ESA
Efficiency: 90 dB
Pictures
Videos
^^^^^Yowsa, great speakers guys
FYI he's in North Carolina2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Yes, but I am willing to drive to meet (because they fit in my car)
Appreciate it!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Listed on EBay - http://www.ebay.com/itm/-/152494520413?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Hi,
I'm very interested in these speakers. You sold me a set of def tech 8020ST back in September. I am on vacation and really need to put a tape measure on my space to see if these are going to overwhelm compared to the 8020s. Thanks,
Mark Gerstle -
I could meet you in Knoxville as I'm in Louisville. Would that work for you?
Email me at mgerstle@gmail.com
Mark GerstlePost edited by mgerstle1965 on -
Hey Mark! These will be an excellent upgrade over the 8020 (even the 8060)
I will send you an email- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yeah, get these suckers home AND IN THE HOUSE, then call me and I'll come over and check them out while drinking your expensive coffee, budd.
Just for Polk members, all of the mids are original and work great, but I will include four extra midranges for free, just for Polkies. The mids are about $80 each from Definitive- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trey, which centers match well with these?
- Best Case
1) CLR3000 - Dual 6.5", Same tweeter + 10" Subwoofer
2) CLR2000 - Dual 6.5", Same Tweeter
3) CLR1000 - Dual 6.5", Similar tweeter (but make sure it is the "sock version" and not the grill/cabinet version). The grill/cabinet version is garbage.
- Space Constraints/had to make it work
1) CLR2500 - Dual 5.25", 8" Sub, Same tweeter
2) CLR2300 - Dual 4.25", 8" Sub, Same tweeter
- Found a good deal, have it on hand
Polk CS1000P, CS400i, CS400, CSiA6, IMO, YMMV. The LSiC line does not have the output to hang with the 2000.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Awesome thanks!
No problem!
The second review I posted, they review the 2000 system (mains/center/surround)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sale pending- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Might be interested in getting my CLR 3000 pimped out I'll drop you a line through your website.HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Absolutely Gwh!
These are sold- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Congrats those are fantastic speakers!
