PB 1000 is dead, any suggestions on what to check
afterburnt
afterburnt Posts: 7,892
Until I can speak with SVS on Monday? I did the obvious stuff.
    txcoastal1 Posts: 13,124
    Fuse?
    Tried both Line and LFE input?
    Pulled amp visual and smell test?
    Auto standby switch?
    Plug from wall is hot...ie not on switch?
  • afterburnt
    Did all that except to look for a fuse. I have no Idea when it died it could have been weeks if not months.
    I'm not even sure there is a fuse...just a laundry list
  • Paradoxex
    Paradoxex Posts: 189
    My PC13 seemed dead when I had to move it to our basement. Reseating the fuse brought it back to life.
    It was on the amp, but I do not know how that translates to your sub.
  • afterburnt
    @Paradoxex, I am good just figured I'd ask. Humping this thing out of is spot is hard, my body aint working so good these days. SVS will most likely help on Monday, they have been really good in the past.
  • arekon
    arekon Posts: 77
    if it has been months and you just noticed then theres a bigger problem at hand...
  • afterburnt
    It's my bedroom system and I don't use it that much these days.
  • afterburnt
    Wow, I need a 3mm allen wrench. I have tools for days, except that. Ugh.
  • mrloren
    mrloren Posts: 2,454
    afterburnt wrote: »
    I hate it when that happens. Most of the time it's after 10pm when HD and Lowes are closed.
    afterburnt wrote: »
    Use your junk :D:D
    Sorry couldn't resist
