Foam pads for rti a9s
As per the title, some of the sound from my rti a9s is bothering my neighbors and they have asked me to get some foam pads to put underneath the speakers. Problem is, these speakers are rather large and I am having trouble finding foam pads that fit. Do you guys have any recommendations? For reference, the rti a9s dimensions are 21" deep and 7.8 wide according to the specs. Thanks!!
Try to make your own from that stuff used for working out and lifting weights.Speakers: Polk - Front RtiA9 - Center Csi6 - Surrounds RtiA1 - Heights Sc60 - Sub Psw125 +SVS PB2000
Power: Anthem MRX1120 11 ch. Atmos/dtsx receiver
TV: Vizio m70c3 4k led TV
Player: Philips bdp7501 uhd player -
How about simply turning the volume down to please your neighbors. You don't want to put foam pads under speakers.HT SYSTEM-
lsi 9's -
