Power Circuit Upgrade
I just finished closing the wall to an upgraded power circuit for my 2 channel system.
I installed a sub-panel with four 20 amp dedicated circuits. Each circuit has 10/2 MC cable feeding two duplex hospital grade outlets.
The panel is fed via a 60 amp breaker with #6 wire and has a #4 solid wire ground.
In addition the sub-panel is protected with a panel mounted surge protector.
I sold my Tripp-Lite 2400 (with noisy transformer) and am plugging everything directly into the wall.
I separated my components between the four circuits as listed below:
1. Amplification
2. Analog
3. Digital
4. Video
I am very happy with the results.
I seem to drawn into the music no matter which source I select. :)
1KVA Dreadnought
Marantz SA 8005
Sony PS4
  • rpf65
    rpf65 Posts: 2,127
    I'd still use a power conditioner for everything but the amps and subs.
    Just my opinion, but I think you actually have less protection for your electronic components with the whole house type surge protector than you did with the Tripp-Lite, providing it was in good working order.
  • HzTweaker
    HzTweaker Posts: 723
    machone wrote: »
    1. Amplification
    2. Analog
    3. Digital
    4. Video
    ^This is cool. When I grow up and buy a home I'm going to install a similar setup.
    2ch rig:Speakers: LSi9s with VR3's Fortress modsPreamplifier: Parasound P5Amplifier: Parasound A23CDP: Pioneer DV-563ACables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    EndersShadow Posts: 17,517
    rpf65 wrote: »
    You must have missed the part where he said the subpanel has a panel mounted surge protector... which means the entire panel (and anything running off it) is protected.
    I have one on my main system and have 3 dedicated lines for my HT and the main reason I still run my ALC H15 is because it has more outlets than the regular wall.
  • MrBuhl
    MrBuhl Posts: 2,419
    That's drool-worthy. I was so happy to install two 20 amp circuits in mantown in VA, I didn't dream of anything like this...
    All the while my electrician, a very nice Russian fellow saying... "you know... this eese something you do not neeed... eet eese in your head... not your earrsh."
    Yea, I've heard it before, just install it baby! Difference? Fo Sho!! Congrats!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • machone
    machone Posts: 1,471
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    pitdogg2 Posts: 24,481
    edited March 2017
  • gp4jesus
    gp4jesus Posts: 1,969
    When I build my dedicated HT I want my system...
    machone wrote: »
    ...protected with a panel mounted surge protector.
    Where do I get one?
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • lightman1
    lightman1 Posts: 10,776
    gp4jesus wrote: »
    machone wrote: »
    Where do I get one?
    Lowes, Home Desperate, electrical supply house, Menards......
    New Orleans? I can have it installed in a jiffy. Just ask @EndersShadow........
  • gp4jesus
    I have a HD & 2 Lowe's w/in ~15-25 minutes depending.
    Thnx
  • machone
    gp4jesus wrote: »
    machone wrote: »
    Where do I get one?
    As others have said "Lowe's/Home Depot, etc".
    Mine fit the sub-panel and took up two circuit breaker slots. If fitting into a panel make sure the surge protector is compatible with the panel.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Mike Reeter
    Mike Reeter Posts: 4,314
    edited May 2017
    Nice job machone! Whole House Surge Protector here also, I wouldn't be without one, if at all possible.
  • afterburnt
    afterburnt Posts: 7,892
    @machone why seperate the components that way?
    afterburnt wrote: »
    No cross noise contamination. Each will have its own dedicated circuit.
  • gp4jesus
    FWIW: I have my left* & right** tower amps on separate breakers.
    * shared by the CC amp
    ** shared by sub
  • machone
    edited November 2017
    Last night I upgraded two outlets with Furutech copper outlets. One for my amplifi cation and one for digital. Got them from Doug.
    Had a great listening session afterwards.
    I plan to upgrade the power cords to the preamp, computer power supply and Marantz 8005 next.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    Looks right purdy!
  • We have the Furutech FPX-CU receptacles on sale right now. And as a Polkie you'll get another 10% off. Click on contact us and give me your Club Polk handle along with what you want to order. We have a lot of goodies on sale right now, so check out the specials page.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • machone
    If there is anyone on the fence thinking about an receptacle upgrade I recommend trying the Furutech FPX-CU.
    I must say I have been pleasantly surprised that this could really improve SQ. Seems to be more air around individual voices and instruments with tighter bass and a sweeter presentation.
    Sure would like to hear someone else's experience on this to verify that I am not crazy. :p
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • gp4jesus
    Recall the $? Hypothetically I need 5
    Viking64 Posts: 6,646
    machone wrote: »
    Make sure you also upgrade the wire leading to the panel box, and the breaker, and the panel box itself, and the cable leading to the meter, and the meter pack, and the meter, and the drop from the transformer. Also, make sure all of the power lines from the transformer back to the power generating plant are upgraded.
  • machone
    Viking64 wrote: »
    machone wrote: »
    Already Done! >:)
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    machone wrote: »
    Already Done! >:)
    I just thought of something. Are the ground conductors in the MC isolated from the junction boxes? Are the receptacles? Inherently, the metal armor is grounded to those boxes and the panel box.
  • machone
    The MC metal armor is grounded to the sub-panel but the receptacle box is plastic.
    The MC ground conductor is grounded to the sub-panel and the receptacle.
    I got a lot of good info from the attached White-Paper.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    machone wrote: »
    That sounds like the most ideal method. I had never seen MC run to a plastic box. That's why I wondered. :)
  • lightman1
    machone wrote: »
    Viking64 wrote: »
    machone wrote: »
    Already Done! >:)
    You're welcome.
  • machone
    lightman1 wrote: »
    You're welcome.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • machone
    I continued to upgrade the power circuitry. I added new power cords for the Quantum Byte/Mojo power supply, Marantz SA8005 and Hafler DH110 preamp.
    I used Furutech FI-11M and FI-11 connectors along with Furez FZ100BS sleeving. Got these from Douglas Connection.
    I combined these with 12awg shielded cable from VH Audio.
    It took a while to burn in but the results are outstanding.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
