Sherwood AD260B
RSTERN
Does anyone have any info. on this amp. Pick it up at a thrift store along with a Pioneer TX-410 tuner. Tried a google search for info on the amp and all i came up with is for a manual. Kinda wanted to know how many wpc and if you can run a and b speaker at the same time?
Rob Stern
Rob Stern
mains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+
Post edited by RSTERN on
Found nothing on your model, but surprisingly (to me anyway) Sherwood, AKA Sherwood NewCastle, is still around.
Try writing the folks here:
http://www.sherwoodusa.com/More later,
Tour...
Vox Copuli
Thanks for the link. I will send them a e-mail.
Had it hooked up some rti38, they sounded really good, but that was on the dining room table
Robmains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+ -
You're welcome...
Ah, the old "dining-room-table-test-center"... I've got one of those...
More later,
Tour...
Vox Copuli
Rob Stern
I've owned one of these amps for 20 years. I purchased it as part of a system, and it's the only component that remains. It owes me nothing-- it survived my last two years of high school, and then years of college and post-college parties and daily--DAILY--abuse. It's been moved around and plugged/replugged countless times with all kinds of crappy speakers attached to it. I've had it repaired twice for a combined total of around $100. The sound quality isn't great, but it's not that bad. It's currently driving a pair of Bose 301s (they've been along for the ride since 1989) and Spica Angelus (seriously!) speakers and doing just fine. It puts out 120 WPC if I remember correctly. When I think of what I've put the thing through, I'm truly amazed that it still functions--every single knob, light, port, and feature works, though the volume knob cover came unglued and fell off within a year of purchasing. The logo has worn, so it says "S e oo ", but that just adds to its charm. -
I have one of these amps.
I have had it since 1994 and I love it.
I don't know WPC but would like to.
I do know that it ouputs enough to make it too loud to be in the same room
when on full.
Cheers
