Custom Tweeters!! RDO-198's
Toolfan66
waiting to see finished product
While I do like, won't the stacked plates act as a small waveguide?"Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
my thought also. So Larry saying he wasn't done I'm reserving until I know/see more -
The delrin and the face plate will be bonded together...
The outer metal circle will change the radius of the radiation of the radiant nature of the dome.....HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Every change made to either the length or the angle changes deflection angles.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
They are not done yet, and this is costing me all of $27 to do this, if it doesn't work then I reverse it back to stock, but I have faith it will work out just fine!! :-)
Keep in mind everything I'm doing to these speakers is for fun, and it's all reversible if I don't like it.. :-)
Also it helps having something to keep my mind on other things, and my hands busy.. -
Larry, is it not possible to entirely replace the stock plastic bezel with an aluminum one?Political Correctness'.........defined
President of Club Polk -
That was the plan at first but when you take the tweeter apart you realize the positive and negative wires are exposed and the aluminum will connect them..
There needs to be a barrier...
The inside hole that you see still needs to be machined, it was lasered small on purpose for final machine as well as the four holes to be drilled and c/s, I have stainless screws for the assembly...
Ah ha, I figured you'd have that answer.Political Correctness'.........defined
I was thinking of something similar bu with one long piece housing all 4 tweeters... Love the look of these.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Remarkable idea, remarkable workmanship!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
