WTB 2.3TL interconnect please
VjMac3
Hi- I am the proud new owner of a pair of Polk Audio SDA SRS 2.3TL Reference Speakers, but lack the interconnect. I am sure you have seen this a million times already but could someone point me in the right direction to buy or get aftermarket? Hell, even how to make one if needed... Thnks- VJMac3
Ok, other than the info provided via PM as a temporary make-do you can use RCA jacks with the outer collar removed as only the pin carries a signal when using a common ground amps. If you are using non-common ground, dual mono or mono blocks it's a different story.Political Correctness'.........defined
President of Club Polk -
Thank you very much. I will try that today and also study up on the suggestions sent earlier.
Looking forward to doing some listening today!
