I need help deciding what series are my speakers and what tweeters to get
Oldreliable7m
I got a pair of polk monitor 7s need help on deciding what tweeter i need that will fit my speakers and it would be nice to know the series to
The tag Reads Polk audio Monitor 7 24198 Thanks
Post a picture with the grill off.Political Correctness'.........defined
President of Club Polk -
I currently have goldwood tweeters from parts express and they suck -
Here is the crossover -
Whoa.......they are a bit of a mess. Ok, there is no fuse on the back, so they are likely 7C's, but you should pull the crossover to compare with the schematic posted here.
Those driver/PR screws are not the correct ones and the driver screws are in the wrong location. It also appears the binding post plate is cracked. I can't tell for sure, but it appears the two bottom screws on the tweeter are going through the bezel, not the tweeter cut out.
I take it you just bought them?
One other thing, the red (positive) nut should be on the left, black on the right. However, you should verify that the wires haven't been swapped inside.Political Correctness'.........defined
It looks like someone replaced the tweeter with a JBL (or knock-off) tweeter.
If you remove the PR and snap a pic of the actual crossover components we maybe able to give a better idea but you likely want the Polk replacement tweeter RDO-194 which is an upgrade.Stan
Main 2ch:
HT:
Other stuff:
Holy.... that midwoofer looks like it's taken some dings and those screws... you might need hurricane nuts or Larry's rings. You'll find out.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Thank you all very much thank you all for the information these where actually my uncles garage speakers so they have taken quite a beating over the years I picked them up not to long ago he wanted smaller speakers I think these polk speakers are a diamond in the rough I can't wait to get the crossover upgraded and I'm sure they will sound awesome I'll take a picture of the crossover in the morning.
Where are you located. I may have parts that will help. No charge.
I'm located in Aurora Colorado.Post edited by [Deleted User] on
Posting you phone # isn't the best idea. If you have time to edit I'd take it out.
Oh boy, time to make some prank phone calls.2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact.
Imagine making politics your entire personality. -
There's 10 pizzas on the way to your place.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
He needs a new Direct TV system, too.
Plenty o' phone reps need his #. -
Male dancers will be there at 3PM for a bachelorette party.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Well the good news is the passive radiator seems to be in good condition. The tweeter and the mid woofers are easily available.
The passives are harder to come by, so you may have dodged a bullet.
Have fun!HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
BR: iPad Mini, Audio Engine A5+
2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM -
No air leakage around those tweeters....
Those look like a "fun" project.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
Yes yes they do But there better than my sda-1c i got form a mechanic that had them in a garage
Have you gotten anywhere with it?
It's been a year, hopefully the are positive results? -
not quite yet ill get to them after my sda-1cs im going to use the old sl2000 tweeters from my sda-1cs and put them into the monitor 7s then im going to upgrade the crossover sense they might be damaged or upgrade the midbass and see how they sound after that
its kind of hard juggling car problems and the project that i know ill love doing
