Polk RTA 12 B Overhaul
Here are a few pictures of my overhaul project. I started with a pair of Polk RTA 12 cabinets that were in average condition. The plastic laminate covering was torn off one side of one cabinet, but other than that they were in good shape. I decided to finish the cabinets in Cherry, and build custom bases for them to sit on. I also decided to move the crossover inside the cabinet and make customer mounts for the tweeters, leaving them uncovered. I also did all the 'standard' modifications such as hurricane nuts to mount the drivers, extra bolts in the PR, dynamat on the driver baskets, new seals all around, rebuilt crossovers, dynaliner in the cabinets, new posts on the back, and JB weld on the magnets. I'm probably going to bite the bullet and buy some Black Hole 5 to place behind the drivers as well.
For the cabinets, I wanted to go with a furniture look. The cabinets are a box, and all they are ever going to be are a square box. So I took my design cues from Mission style furniture, which I like, and which deals nicely with a square box look.
In the pictures below, we have finished all the rough work and have them stained. I have yet to decide if I am going to fabricate a speaker grill of some kind, or if I am going to just leave them open. I don't have any kids running around so that is not a major concern.
The next two phases will be a few coats of sealer, then several coats of lacquer. I'll post more pics as we progress.
Carver C-1, M-500 MKII, Yamaha HTR-5835, Polk RTA 12BM's (M-for mod'd).
    xschop Posts: 5,443
    Polk Mission editions.....nice.
    pitdogg2 Posts: 27,410
    Well that is unique and stylish. Will the bases be attached or will they just sit on them? Do you have room on the feet for spikes?
  • Michael8it
    Michael8it Posts: 192
    The speakers will sit on the stands on a very thin piece of open cell foam ( so I don't tear up the base and to keep it from sliding around. The were designed to have spikes. Holes have been drilled but I will install those at the last step.
    Why not attach them to the base? I think they look good together. Won't the foam inhibit bass transfer to the floor?
  • Michael8it
    The foam is 1/16th on an inch thick, just enough to prevent scratching. I added 3/4" plywood to the bottom before I started finishing them to add some mass at the bottom. The spikes will de-couple the speakers from the floor so permanently mounting the speakers to the base to get bass to transfer to the floor would seem to be a moot point. The base is completely open underneath so if it turns out that permanently mounting them to the base is the best way that is still an option.
  • Malbec
    Malbec Posts: 558
    Nice! I like the false through tenons on the bases.
  • Michael8it
    Malbec wrote: »
    That was my brother Tom's idea. I liked it!
    I could not have done this project without him. Plus a friend works at a fabrication shop and was able to cut the tweeter mounts on a CNC machine so they are perfect.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Very nice, anxious to see the finished product!
  • K_M
    K_M Posts: 1,631
    Very impressive!!
    Follow your heart, and do what makes you happy. Looks great.
  • dromunds
    dromunds Posts: 10,148
    Sweet! Tweeter mounts look awesome. Whole project is awesome. Nice shop also. Lol.
  • Wow! I never thought of that. I have a pair but they're the "A" version. I was planning on moving them on but I might reconsider.
  • Michael8it
    If you can get B/C crossover you can convert them, which is what I did.
    heiney9 Posts: 25,534
    edited March 2017
    Nice woodwork.
    I assume you are mounting the tweeter exactly the same as stock since these are a "real time array" speaker? Also I wonder about the fact that tweeters now have a bezel around them with a lip, might affect dispersion.
    If the dispersion and tweeter characteristics are altered they will no longer be time aligned and that could hurt the awesome performance of these speakers.
  • Schurkey
    Schurkey Posts: 2,122
    Michael8it wrote: »
    Enough to decouple the speaker from the stand.
    Michael8it wrote: »
    Spikes couple, not decouple.
    Ideally the speakers are coupled to the floor, to prevent the speaker cabinet from moving due to the motion of the driver(s). Adding a sheet of foam is a mistake.
    F1nut Posts: 52,045
    Great idea and first class work. I can't wait to see the finished job.
    Schurkey is correct about the spikes.
  • Michael8it
    heiney9 wrote: »
    Nice woodwork.
    Yes, I took several measurements to make sure the tweeter wound up in the exact same spot. I knew moving it would be an issue.
  • Michael8it
    Schurkey, thanks for the info. I will have to find a way to mount the base to the cabinet and allow for disassembly for transporting. I think I have that figured out. I'll also need to finish the plywood on the bottom so it does not tear up the base when I mount/dismount it.
  • drumminman
    drumminman Posts: 3,396
    Looks great ! I especially like the tweeter mount and diffraction plate. Makes me want to do this to my 12C's.
  • Michael8it
    Here are some updated photos. I had some issues with the veneer bubbling up that I could not resolve, so I will live with that for now. Finish is not quite what I wanted but again, I will take it for now. Working on the internal wiring and waiting for my polyfill to arrive. The cabinets are not currently mounted to the base, but there is enough weight on them for now, and I will look at how to bolt them together later.
    I'm particularly happy with the tweeter mounts. These were made from reclaimed cherry and I think they look fantastic.
    I also put in t-nuts on the drivers and the passive woofer. I think I will do this for the crossover on the back as well. I upgraded the posts and the wiring as well.
    After looking at them assembled I wish I had made the base a bit taller. Still happy with them though as they stand a few inches taller that the original 12B's.
  • DaveHo
    DaveHo Posts: 3,583
    They look very nice! I'm curious what effect the edges you've introduced will have on the sound.
  • Michael8it
    DaveHo wrote: »
    Hopefully none. The original grill these came with was raised the same distance, it was just covered in cloth so you could not tell. I hope to finish the wiring this weekend and fire them up.
  • Faustin
    Faustin Posts: 1,151
  • Dabutcher
    Dabutcher Posts: 2,606
    Beautiful work. You inspire us all with your greatness! Peace. D
  • Michael8it
    I'm having a challenge re-wiring these. The schematic I have shows the + side as black wires, and the - as white, but that does not appear to be how these were originally wired. If someone who has a pair could take some photos of where the leads are coming off the top crossover for the mid and tweeter I would appreciate it.
    I know the tweeter is wired out of phase because of the distance to the drivers, but the driver wiring does not seem to line up with the schematic either.
    Thanks,
  • voltz
    voltz Posts: 5,384
    edited July 2017
    yes, the black wires are + in the vintage polks like my CRS+'s & SDA 2B's and the monitor 10's. and on all 3 of these the black wire is positive for the tweeters also.
    I don't know about the others like yours.
    my crossovers
    Black is positive. I believe that the tweeters get reversed in the XO so that is why they are wired out of phase at the tweeter.
    At least that was my understanding.
    I could 180* wrong
    :p
  • delkal
    delkal Posts: 764
    edited July 2017
    I did a quick peek inside my 10a and I noticed one black wire connected to a white wire! Didn't have time to trace where everything went yet but that was definitely confusing. I hope no one was messing with the internals.
  • Michael8it
    delkal wrote: »
    I think I'm running into the same issue. I am going to go with what the schematic shows and ignore the wire colors I see.
