SACD & Marantz?
Have a Marantz SR 5011 AVR & Oppo UDP 203. Trying to play a SACD. Appears Oppo is reading disc. Can Marantz play that signal?
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
  • nbrowsernbrowser Posts: 7,914
    Yep, just make sure the Oppo is connected to the SR5011 via HDMI and select the right input.
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
  • UpstatemaxUpstatemax Posts: 2,189
    edited March 2017
    Just make sure that the SR5011 will accept DSD over HDMI (it should). Only thing I could easily find for it was that it will accept DSD signals over USB.
    Also, make sure you don't have to use a specific HDMI out on the Oppo 203 to output the DSD signal.
    I can't remember what one it is on my 103, but only one of the two HDMI outputs will output DSD.
    Living room:
    Samsung PN50B860 50" Plasma : XBOX One : Roku 3 : Oppo BDP-103 : Pioneer Elite SC-87 : APC H15 : Focal 806V mains : Focal 806V Surrounds : SVS SB2000 : SVS SB12-NSD
    2Ch:
    Sonus Faber Venere S : Parasound HCA 1500A : Oppo UDP-205 : Furman Elite 15 DM i : Sony XBR 55X810C Monitor :
  • tonybtonyb Posts: 28,937
    He could also use the analog outs on the Oppo if he has it set up that way.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    tonyb wrote: »
    True...but even my BDP93 and SR5010 thru HDMI worked on the first crack, even better after I told the Oppo to only output SACD in stereo.
    nbrowser wrote: »
    I guess it would depend on what DAC you would want to use.
    Analog outs, Oppo's built in DAC is doing the work. HDMI out can let the Marantz's DAC do the work.
    I know you know that, but I'm not sure the OP does...
    Living room:
    2Ch:
    Upstatemax wrote: »
    nbrowser wrote: »
    Very true, that said though I prefer letting the Marantz do the decoding over the 93, sounds a bit better to my ears at least.
    nbrowser wrote: »
    It depends on what system my Oppo 103 is residing in.
    If it's in the HT, I prefer the SC-87's DAC. I just let the Oppo act as a transport and media server.
    In my 2ch, I like the Oppo's DAC over the P5's. However, I HAVE to let the Oppo do the decoding for SACD in my 2ch system. Either way, I still prefer the Oppo's DAC for all playback over the P5's.
    Living room:
    2Ch:
    Sounds more and more like a case of "read the manual". Most likely a set up issue in the players settings.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
  • [Deleted User][Deleted User] Posts: 25
    edited March 2017
    Forget both those players Kingkwas, I'd wait for the new Oppo UDP-205 & get it sent to Dan Wright (Modwright) for truth mods. He is planning on offering his usual two-chassis tube mod with truth umbilical & said it will be his best mod ever. He is also offering a lesser cost single chassis solid state mod which will also be very good. I plan to go for the single chassis mods with the Bybee Music Rail upgrade. On top of that I plan on adding Telos Quantum stickers in strategic locations ;).
    David
    Front End: Vitus SCD-025 Mk2, Oppo BPD-103AU Amplification: Vitus SIA-025 Speakers: Magico S5 Mk2 Isolation: Taoc ASR series racks, Taoc SCB-RS-HC50G, Stillpoints Ultra 6's + Bases/Mini's/LPI's AC Power: Furutech GTX-D(G), Gigawatt PC-3 SE Evo, Jorma Prime pc's (re-terminated with cryo'd Oyaide M1/F1’s), Jorma Unity pc (re-terminated with Oyaide P-004/C-004’s) Cables: Jorma Prime xlr's + Statement sc's, Siltech Classic Anniversary rca's + HDMI Tweaks: Acoustic Revive RR-777 + KR Mk2/RD-3/RIO-5II/RCI-3H, Akiko E-tuning Gold MkII
    "If music be the food of love, play on.." - William Shakespeare
  • F1nutF1nut Posts: 39,490
    edited March 2017
    He has the Oppo UDP-203 already, the Marantz is his AVR.
    Edit: corrected.
  • NightfallNightfall Posts: 7,425
    He has the Oppo UDP-205 already, the Marantz is his AVR........hello!
    The 205 isn't out yet. Hello! :p
    afterburnt wrote: »
    edited March 2017
    Read the Op again....UDP-203 is mentioned...HELLO! :)
  • lightman1lightman1 Posts: 9,396
    Howdy!
    Friendly bunch 'round these parts.
    edited March 2017
    LOL......203, 205 what's the difference, it's an Oppo.
    I'm thinkin someone around here is a blind old guy...and I'm fairly well stocked up on vowels :smiley:
    nbrowser wrote: »
    Woohoo !! I'm off the list. Jessie took my spot.....woooohooo !!!
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Not so fast there Tony, there's no i in my name.
  • voltzvoltz Posts: 4,922
    Just ask Carly Simon
  • KingkwasKingkwas Posts: 61
    Thanks everyone for the input. I talked to some Oppo support folks. Played some with the settings but honestly didn't do anything. Put everything back to the way I found it. It just randomly starting working.
    I know my setup isn't true audiophile yet (Polk LSiM 703 bookshelf, Marantz AVR (BiAmp'd & Oppo player) but can not tell much (if any) difference between a CD & SACD. Maybe some but its not revolutionary.
    Thoughts?
    R: Def Tech
    DVD: Oppo UDP 203
  • rpf65rpf65 Posts: 1,632
    What cables are you using?
    rpf65 wrote: »
    All HDMI
    R: Def Tech
    DVD: Oppo UDP 203
    Don't expect mind blowing differences. It's all in the details.
    I've typically found less smearing of the soundstage, better overall dynamics and greater detail with SACD.
    A lot of it can depend on what SACD you're listening to, not all are created equal...
    Living room:
    2Ch:
    Kingkwas wrote: »
    rpf65 wrote: »
    All HDMI
    I'm that case you are using the DAC in your AVR. Try using RCA cables, which will utilize the DAC in the Oppo.
    Update 2.0: Continue to have issues. Been back and forth with Oppo. Connected via HDMI. Will not play SACD. Plays everything else. Randomly on 4th try it started to play SACD. For no reason it just plays sometimes. Will try again tomorrow. Did install a new HDMI cable. Not sure that is it because it can play 4k DVDs fine. Also plays CDs just fine.
    R: Def Tech
    DVD: Oppo UDP 203
    Might also be a change in "Audio Output" settings. Changing to bitstream might have done something. Not sure. Need to test again. What is bitstream?
    R: Def Tech
    DVD: Oppo UDP 203
  • [Deleted User][Deleted User] Posts: 91
    edited June 2017
    = Donald Trump tweets?
    not good on Oppo as I was trying to get worked up about the 205...
    though it could be an Marantz issue as well.
    Studio 2 equipment;
    Yamaha a-s2100 Amp, CD-2100 CD player, T-S500 tuner
    Loudspeakers: Harbeth p3esr, Polk RT7
    Cables: Aural Harmony Sonnet Interconnect II, WireWorld Equinox 7 speaker,
    Black Cat silverstar 75 ohm digital, Signal Digital Power Cord, PS Audio Perfect Wave AC-3,
    Pangea SE14, Voltz supplied interconnects
    Optional: Arcam DV88 DVD/CD (HDCD) player, Polk SDS-400 speakers
    Kingkwas wrote: »
    This happened with my NAD 758 AVR & my Oppo 103, If the Oppo was set to Auto I could hear the SACD but it was playing as a PCM via HDMI
    If I told the to force (not auto select) SACD and I got no sound, because my NAD AVR could not decode DSD.
    So I hooked it up via Analog cables as Tony suggested so that the OPPO's DAC decoded the DSD file for me and I had sound that was actually DSD not PCM..
    voltz wrote: »
    Kingkwas wrote: »
    What is the difference between DSD and PCM?
    R: Def Tech
    DVD: Oppo UDP 203
  • pitdogg2pitdogg2 Posts: 9,669
    edited June 2017
    Clocking rate
    Scroll down to pcm- dsd
    http://www.mojo-audio.com/blog/dsd-vs-pcm-myth-vs-truth/
  • BlueBirdMusicBlueBirdMusic Registered User Posts: 264
    From Marantz website re HDMI features for SR5011. Notice the "X" beside DSD.
    From Marantz website and SR5011 manual. Tony and Voltz gave you the answer - use analog cables (RCA L/R) to the AVR from the Oppo.
Howdy, Stranger!
