Wanted: Speaker Grille Posts from Monitor Series
One of the plastic speaker grille posts on my Monitor 10B's is broken off and I am looking for a replacement. If anyone has some extra that they want to sell let me know. I really only need one, bu would buy more if needed.
    F1nut Posts: 49,802
    Parts Express sells one version/size that is very close.
  • soundfreak1
    soundfreak1 Posts: 3,387
    I've used them, they fit very well.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    pitdogg2 Posts: 24,579
    I did also they're legit
  • jayu969
    jayu969 Posts: 112
    Thanks for the info! I will check out Parts Express.
