2 TB HD reformatted to FAT32?
All of my stuff except for the Oppo says it is limited to 2TB in FAT32 format. They are all USB type A sockets (except the Oppo). All of my HD's are formatted NTFS. Has anyone needed to change the format to FAT32 on a drive in order to play music on a device that requires it, if so were you successful?
    txcoastal1 Posts: 13,124
    http://watershade.net/wmcclain/BDP-103-faq.html#what-are-the-specs-of-the-digital-inputs
    Media Files
    What file systems are supported on external media?
    FAT, FAT32, exFAT, and NTFS.
    I believe the older 93/95's did not support NTFS
  • Nightfall
    Nightfall Posts: 10,042
    edited March 2017
    93 supports NTFS on my end.
    Only problem with FAT32 is single file size is limited to 2Gb so no high res BluRay rips or single file 128 DSD or 192/24 FLAC albums.
    Yes, reformatting in FAT32 would fix your issues on those devices that require it.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • afterburnt
    afterburnt Posts: 7,892
    txcoastal1 wrote: »
    Media Files
    Ron, the issue is with everything except the Oppo.
    @Nightfall, I will try it, I just hope I don't wipe out all of my stuff. I am stoopid like that.
  • Nightfall
    edited March 2017
    Oh, stop. Reformatting to FAT32 would absolutely erase everything on the drive. Back it up first. @afterburnt !!!
    Sorry, I figured you knew that.
    afterburnt wrote: »
    Nightfall wrote: »
    There is way to do it....but yes back it up
  • Nightfall
    I hope he reads this thread before he does it. :#
    How can you convert without losing data?
    afterburnt wrote: »
    You still have to create partitions but you can't create partitions if the drive is full
    Once you create the partitions you can format each one at a time and move the files from 1 partition to the other after formatting...PITA
  • afterburnt
    I got a backup lol
  • afterburnt
    "nnMaximum Number of Playable Files and Folder
    The limits on the number of folders and files that can be displayed by this unit are as follows.
    Media
    Item USB memory devices
    Memory capacity FAT16 : 2 GB, FAT32 : 2 TB
    Number of folder directory levels z1 8 levels
    Number of folders 500
    Number of files z2 5000
    z1 The limited number includes the root folder.
    z2 The allowable number of files may differ according to the USB memory device capacity and the file"
    I may be screwed just the same, I have way more files and folders.
  • tophatjohnny
    tophatjohnny Posts: 4,162
    I have found that the Cambridge Audio Stream Magic 6 as well as all of the Onkyo receivers are limited to a max of 2TB drives, hence the reason I now have the NAS up and running and ain't looking back!!
  • afterburnt
    I have to get a NAS before I go insane
