DSW Pro 660 wi?
How much of an upgrade would it be over a PSW 505? What is comparable in same price range?
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
    F1nut Posts: 49,794
    For HT, it should quite an improvement.
  • Kingkwas
    Kingkwas Posts: 92
    Would it perform better for stereo too?
    R: Def Tech
    DVD: Oppo UDP 203
  • polrbehr
    polrbehr Posts: 2,826
    I would think it would be more than adequate for stereo, those DSW subs perform very well for their size.
    For comparison, SVS has a B-stock SB1000 for about the same price, though I like that the Polk has a remote and PRO Optimizer.
    F1nut Posts: 49,794
    For music a sealed sub is always better as they have quicker, tighter bass response.
  • mrloren
    mrloren Posts: 2,454
    Yeah what F1nut said.
    On the other side both of my HSU subs are down firing ported subs that do very well with my 70's-80' rock music.
