Mounting amp to sub ok??
I helping my son add a 10 inch sub to his system. Can the sub amp be mounted to the sub box? It would be helpful for when he needs the truck space and the sub needs to come out for short time periods.
  • nbrowsernbrowser Posts: 7,527
    edited February 2017
    Yep, can be done, has been done for years, take the amp and screw it right to the box. I've done it for years. Really no different than a powered home sub, the plate amp is usually attached right to the box.
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
  • 20hz20hz Posts: 643
    should be fine thieves love it !
    I built my box with sunken in sides so the amps sit flush , well the next morning I came out to do the fun wiring to find a broken window and the box w/amps were gone .
    Big bummer well that was the first and last time I did that !
  • I don't see anything wrong in doing that except it would look better and would be a space saver. I actually just did that with the newly purchased subwoofer that I bought from 4wheelonline when I bought a set of Michelin tires
Howdy, Stranger!
