Best FLAC interface?
As much as I love the performance of my Oppo 105 for playing FLAC files off a portable hard drive, I am not crazy about the Oppo interface. Specifically, there is no way to quickly access a specific artist, or search an artist - you have to scroll through all artists alphabetically.
Is there a better way, using the Oppo to access FLAC files?
"Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
― Aleksandr Solzhenitsyn
  • steveinaz
    steveinaz Posts: 19,522
    edited February 2017
    You can use the "page down" button on the remote to scroll multiple artists instead of going artist by artist. Does that help?
  • daddyjt
    daddyjt Posts: 2,329
    It helps, but I've got about 650 artists in my FLAC file, and over 3000 in MP3. So if I want Van Halen, it's a hike. I thought about breaking my FLAC file into 5 or six smaller files, like A-F, G-L, etc... but I'd prefer a different interface, especially if it included a direct path via a search feature.
  • BlueFox
    BlueFox Posts: 15,251
    Try the Lumin app on the iPhone or iPad. It's free, and is based on some standard, same as Linn, and works well for the USB drive I attach to the Lumin. It just needs to be able to see the Oppo IP.
  • BlueFox
    BlueFox wrote: »
    They say it supports standard UPNP for browsing folders. So if Oppo supports that it should work.
    http://www.luminmusic.com/lumin-app.html
  • daddyjt
    DSkip wrote: »
    Can you treat it like a dlna device and stream plex or jriver to it?
    I do not know if Oppo supports this capability - I will do some research... thank you.
  • daddyjt
    BlueFox wrote: »
    I downloaded the app, and I'll see if I can get it talking to the Oppo... thanks!
  • steveinaz
    http://yabb.jriver.com/interact/index.php?topic=84524.0
    Above is a discussion about JRiver working w/Oppo.
  • RamZet
    RamZet Posts: 792
    edited March 2017
    The Oppo app is awesome.
    You can use Tidal, HDD music or network storage.
    The app is smooth and easy to use.
    Droid: https://play.google.com/store/apps/details?id=com.oppo.mediacontrol
    Apple: https://itunes.apple.com/us/app/oppo-mediacontrol-for-bdp-10x/id699429398
    B&W CM9Classé Sigma
  • daddyjt
    Yes, it is great! I couldn't get it to work at first, but I realized I was trying to use it with my 95, and not my 105. Once I switched over to the 105, it worked like a charm - I run the whole thing from my iPad :smile:
