polk audio speaker box internal crossover
hello.
i have a crazy problem and im wonedering if you can hlp me. i have a polk audio speaker box 10'' woffer one mid one tweeter. the problem u may ask. i was not getting any base, when i took out the speaker it had no magnet on it lol. so i went and bought a speaker. but on the crossover there are no wires for the woffer. maybe i just dont know any thing about polk. im confused. can you help at all.
tnx brett
Best Answers
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Answer ✓
    Hi Brett,
    Welcome to Polk's forum. In all likelihood your speaker uses a passive radiator (no voice coil or magnet needed). The speaker probably has a 6.5" active driver and this is what needs to be replaced. Do you know the model number of your speaker?
    Regards, Ken
  • [Deleted User]
    Answer ✓
    Polk sells them through their customer service department available either at: 1-800-377-7655 select option 2 or via email to: polkcs@soundunited.com I believe they will ship to other countries. Also, they might be found on eBay but use the usual seller ratings for making sure you get a good unit.
Answers
