Need quick advice!
mikeyb128
Looking at a used but looks to be old ps audio power director. 400$ worth it?
2 channel:
Theater:
Theater:
Looks like it is floating on the carpet.... Groovy
Well no quick advice happened here. I passed on this due to age.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Sorry Mike, I wasn't familiar with that one.Political Correctness'.........defined
President of Club Polk -
The seller seemed annoyed I asked how old it is. First sign to abandon the deal.2 channel:
Theater:
I could be mistaken, but if I recall, that particular model had some issues. I'd pass...HT SYSTEM-
lsi 9's -
I picked up something different. And a little out of the box. But made in 'merica and built like a tank.
http://www.corepowertechnologies.com
http://www.essenceelectrostatic.com/product/core-power-technologies-equicore-1200-1800-fully-balanced-ac-power-source/
2 channel:
Theater:
very nice
What is thatMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
I seem to recall the same thing...something about shutdown issues if I remember correctly. -
My research shows it's from 2002... so naturally I blew my budget by about 3 times what I wanted to spend. Should be good enough2 channel:
Theater:
Isn't blowing your budget what this site is all about?lsim705,lsim706c,lsif/x(4)+mc80(atmos)
rti6,csi5,fxi5 -
Hey, quit picking on me!
Cool man, looks beefy. Let us know how it works out when you get her in the door.HT SYSTEM-
lsi 9's -
Will do! The reviews on the smaller 300 model all look very promising. I will be using this to run my front end gear, I will experiment with plugging the amp into it. It was recommended by the dealer here in Canada to do so, and he did actually used my amp in one of his experiments. In my experience I'm likely to leave it plugged into the wall, but we will see. Should have it by the end of the week, just in time for the weekend.
This is a demo unit as well, which is just broken in. I'm told it should stabilize at the 48hour mark.2 channel:
Theater:
