SB6500 Wireless Sub makes popping sound
Makes occasional popping sound even on what I would consider low volume. Only about 2 months old and has done this since day 1. It is connected via bluetooth to the matching soundbar which is wirred directly to my TV.
  • Hello,
    Welcome to Polk's forum. Usually a potential cause of this kind of problem is interference between a network router and the link between the soundbar and the subwoofer. As a test try unplugging your router and see if the popping stops.
    Regards, Ken
