Cardas thruholes.... 1/2" or 13 mm?
Starting a set of thick billet plates and have generic gold posts that require 1/2" holes. Figured I want to drill for Cardas Incase of later upgrade and I sell the spare set.
Has anyone installed the interlocked Cardas plastic bases in alloy?
Best Answers
Answers
    xschop Posts: 4,636
    Thank you, the fleabay ones I looked at had a 0.513" dimension and I thought they could be china knock-offs.
    On another note my plates will machine 1/2" thick with 1/4" step for inset. Do they may a longer set like yours in link above?
    Thanks for your help.
    xschop Posts: 4,636
    edited February 2017
    The odd stainless tapered set screws finally showed along with my Neutrik inputs....
    Another question or two...
    Since these generic posts don't have set screws for the inner wires, is it kosher to simply use an eyewasher style crimp and bolt them down from the inside once they are attached to the plate to avoid soldering to the gold plate?
    Also does it matter which pin/blade wire goes on either Neutrik pin?
    Post edited by xschop on
    F1nut Posts: 49,708
    You are suppose to use M3 (3 millimeter) screws/hardware for the Neutrik sockets and you should have used the 4 pole high current version.
    Solder those connections.
    One should be marked + and the other -.
    xschop Posts: 4,636
    OK, solder it is.
    I went off the tech drawing I found for the nl2mp showing the hole diameter at 0.138" which happens to the major diameter for 6-32 screws. There's no slop in the sidewalls and the taper fits snug.
    I haven't read any threads yet for Neutrik line replacement for the interconnect cable. I'm not sure if pin/blade inputs from factory crossover matter assuming I build the cable to match. Or is the Neutrik cable shielded for main signal?
    xschop Posts: 4,636
    OK. I had some extra coffee, read some more diatribe and didn't see any shielded jargon. Couple clicks and I have a new 10ft pre-assembled 15g Speak-on connector on its way.
    I'll only be pushing 80wpc thru these CRS rarely, and I did see where you guys were using the 4- pin connector on the Big SDAs. That's good info to know. Thanks again. F1 is a pleathora of knowledge.
    F1nut Posts: 49,708
    Ok, see how your screw heads are proud of the flange? With M3 screws they sit flush.
    Another tidbit while we're at it. Only some of the Neutrik sockets are air tight, so folks need to check on that before ordering.
    xschop Posts: 4,636
    Proud by 0.035"
    I just pressure tested them, no leaks thankfully.
    Im line boring the ID of the plates for each Neutrik with a 0.0005 interference fit.
    All of them are within the tolerance of the Neutrik drawing, but I ruminate over my machine fitment like you guys do for your binding posts.
    F1nut Posts: 49,708
    This is with M3 screws/hardware. Zoom in for a better look.
    xschop Posts: 4,636
    Hey that doesn't have any binding posts, hehe.
    Nice work. I think I'll keep these tapped standard with the socket heads. I just saw the Vr3 plates with dome heads?
    xschop Posts: 4,636
    Ok I used the search here and I cannot find the pics of the custom billet plates someone had done I believe in stainless. Anyone familiar with those?
    F1nut Posts: 49,708
    xschop Posts: 4,636
    Thats them. Thanks, I wanted to see how close the posts are to the tapered walls before I cut mine. I dont think I'll inset mine at all due to my large thumbs and the scarce real estate there. Also his cab mount holes are a little larger than factory as well. Im CNCing mine to step them out a touch further so the larger holes drilled in the cabs have more MDF and the hurricane nuts clear the ID of the large factory thru hole.
    xschop Posts: 4,636
    Got some free time to prog the CNC. so I can make them on lathe or mill depending on what size material materializes later...
    xschop Posts: 4,636
    xschop Posts: 4,636
    edited March 2017
    Had to make special vice jigs just for these... A 0.25" mounting lip will never bend no matter how thick the armacell is hehe...
    Is the standard hurricane nut used on the old Polks 8-32 ?
    F1nut Posts: 49,708
    I see something beautiful in the making.
    Yes, 8-32.
    xschop Posts: 4,636
    edited March 2017
    Thanks F1. These will be trick. As you may see the flange is also a touch wider and holes also on a touch larger radii for the hurricane nuts and bolts to hold more formaldehyde and sawdust....
    I'm tapping and facing them with the same finish as the silverface knobs and billet feet I recently made.....
    xschop Posts: 4,636
    edited March 2017
    The shop lights and phone camera have grievances ..
    F1nut Posts: 49,708
    Ok, this is looking different than I thought, looks good just different.
    xschop Posts: 4,636
    Definitely not done yet. I busted a center drill on one of the holes and called it an evening. Ill have to mill it out with 1/2" end mill.
    These are for my CRS project, but another swirled set is for someone else's project and those will be true spiral machining on the outside. He commented something about vertigo hehe.
    F1nut Posts: 49,708
    Ah, ok.
    xschop Posts: 4,636
    The XS-CRS plates breath.....
    xschop Posts: 4,636
    Do you guys normally drill for the major diameter of the 8-32 screw or the shaft diameter of the hurricane nut insert?
    F1nut Posts: 49,708
    The stud of the nut minus the barbs and the best way to install them is to draw them in with a screw.
    The plate looks good, beefy too. I thought you were making a cup type plate at first, but see I was mistaken.
    xschop Posts: 4,636
    edited March 2017
    Cup type doesn't allow much tap depth nor sidewall for the Neutrik. I don't even need a gasket, just PTFE grease or a touch of RTV if that on sidewall.
    Also this design allows up to 3 sets of binding posts if so desired.
    xschop Posts: 4,636
    xschop Posts: 4,636
    Looks like Im going to make a couple sets for monitors without the Neutriks. PM if interested and Ill get extra material.
    Now that I've installed a set, Im going to rotate the flange bolts 45* so fresh MDF is drilled into.
