Magnifi one flashing lights
retengr
Every 5 seconds, four white lights flash on my Magnifi One.
I'm pretty sure this just started after I had to disconnect the system completely to paint the room. After reconnecting, I had to go through the setup to link the subwoofer and to re-teach the Polk to recognize my TV's remote.
Everything is working fine again, but I'm worried about the four flashing lights. How can I fix this? I tried turning the Polk off and on, but this did not stop the flashing.
Best Answer
A suggestion and a question from Polk CS:
"The first thing I would try is to reset the bar by unplugging it from power for 1 minute and then plugging it back in.
Do you know if it still plays the TV when those lights are blinking?"
Ken
Answers
I'm not sure, let me check with Polk for you.
Thanks, Ken--that worked! I should have thought to try that first.
I was surprised to see that the flashing lights continued even after the TV was off--they were still flashing the next morning!
However, the Polk speakers worked fine--with and, now, without the flashing lights.
Paul -
Good, I'm glad that worked. Enjoy!
