Polk db6501 air core inductor replacement?
Very disappointed in these Polks as they have lasted a month till the woofer stopped working.
The air core inductor on the board has broken on one side. Where can I get a replacement air core inductor?
Prefer to buy replacement part rather than rolling one as I have very little electronic knowledge.
Best Answer
  • KennethSwaugerKennethSwauger Moderator Posts: 6,394
    Accepted Answer
    Hello,
    This is a link to the company that handles Polk's car audio products in Australia:
    http://www.directed.com.au/
    Hopefully they can help you.
    Regards, Ken
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
Answers
    Hello,
    The best source for replacements would be via Polk's CS department at: 1-800-377-7655 select option 2.
    Ken
  • lightman1lightman1 Posts: 9,441
    I suspect the Canadians are up to no good again. Check for maple syrup residue.
  • btijetbtijet Posts: 4
    I'm not Canadian, Australian in fact
    Your air cores spin backwards, then.
    btijet wrote: »
    Welcome to the nuthouse. Hang around. We got some cool Aussies in the midst here.
    Rock on!
    edited February 24
    Hello,
    Regards, Ken
    Thanks mate, sorted it out after a month of this post. Ended up buying another Cross over from these guys $70. That blow as well after another 2 months took it back. Guy had to speak to manager or something came back with the newer model or mm model. Wasn't happy as it's different. But it's been about 5 months+ no headaches so I'm wrapped
Howdy, Stranger!
