Anyone doing ON wall speakers?
I'm not ready to retire to a soudbar anytime soon but I have an itch to modernize the look of the front end a bit. Anything good out there?
G
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Sunfire cinema ribbon trio are amazing. I can get new in box for you for about a grandThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Yes. I'm doing "on wall" cuz of room layout constraints.
I'd rather do on wall than in wall as I can dabble in different speakers.
Started with RTi4 and CSi3 and a wimpy PSW303 sub
Dabbled with LSi7s too:
Had RTiA3s for quite a while (and got a 'real' sub - Epik Valor 15" sealed):
Currently using B&W CDM1NT for fronts, CDMC-SE center, still got that awesome Epik:
Cool set up Erik! What do you have in back?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I'd be interested in flatter on-wall, if there is such a thing.
Erik, you've spent a lot of time changing out speakers!
Vienna Acoustics Waltz Grand2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
http://www.audioadvisor.com/prodinfo.asp?number=PBIMW1
http://www.audiogurus.com/martinlogan-motion-slm.html
Here is a couple that will probably work for you. -
What's the budget ? Otherwise this will be all over the map.HT SYSTEM-
lsi 9's -
Dang I forgot about those Sunfire on walls!
Will need to locate a local dealer to get a listen.
B stock & used prices look doable.
Glad I did not give those Epik Empires away I may soon have floor space up front where they belong.
Much thanks for the replies!
HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Thanks - it does the job.
I'm still using RTi4s in back from my first go-round...they do surround duty just fine, and match well with the B&Ws.
Although not as slim as some of the above options, Polk's new Signature S35 is an interesting possibility.Wall Mountable Left or Right Front Speaker
Use two (left and right channels) or three to create an optimal, timbre match front (left, right and center) acoustic array. Featuring built-in four-way keyhole slots for easy mounting.
https://www.polkaudio.com/products/s35
Dskip send me some more info on those Totems
when you get time no hurry.... I just blew my speaker funds on a used camperHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
