monitor 7 grills
leftwinger57
I'm looking for 1 grill frame ideally covered but not a deal breaker. My M-7s are
original w/ the Peerless tweeter and a single outboard fuse holder. If selling only a set will also consider that. I have badges already. One was always broken then just poof it fell apart w/ MDF flying all over.
Thanks Lew.
Thanks Lew.
If you do not find one I can make a frame for you. What badge went poof? I thought the ones I sent you were metal?
