RTA-15TL Tweeter
Are these tweeters available and if they are cost with shipping information would be greatly appreciated.
Thank you
  • F1nutF1nut Posts: 39,766
    CALL Polk customer service on Monday. Order two of the RD0198-1.
  • NightfallNightfall Posts: 7,491
    Apparently the RTA-15TL's have the tweeters crossed over too low, there's a mod someone here came up with to remedy that so you'll not kill tweeters as easy on those. Decato? Degato? I can't remember, just a sec.
    afterburnt wrote: »
    afterburnt wrote: »
  • RicardoRicardo Posts: 10,498
    And that right there will bring your 15tls to a whole new level. Add Larry's rings and you'll have one of the best sounding speakers Polk ever made.
    Maybe I'm biased....
    SOPA
  • K_MK_M Posts: 1,017
    edited January 2017
    Nightfall wrote: »
    This is an interesting idea and read, but got me thinking of a few things.
    1. Why were Polk's engineers not able to realize this "issue", but the forum member mentioned was able to?
    2. The issue noticed by the forum member, was using 15 or 16 year old caps, as his baseline. Any new cap could drastically change the "sound", as the original caps were most likely not good anymore.
    3. Why this issue was not noticed, on several other models, that use similar or the same crossovers, and tweeters.
    4. His modifications were not based on actual measured responses of the drivers in question, but simply based on assumed impedance values, not measured impedances.
    Still interesting though.
    Lsi15, Lsi9, LsiC,Rta11t,M5jr+,M4,SDA 3.1TL, SDA SRS 2.3TL, Rti6....Still listing stuff, a work in progress.
    B+W-
    Epos-
    Infinity-
    Advent-
  • tomb57tomb57 Posts: 4
    K_M wrote: »
    Nightfall wrote: »
    My thoughts exactly
    For the same reason the Polk engineers were not able to realize the issue of the SL2000's 5dB spike. Oh wait they did realize it, but decided to go with it anyway.
  • DSkipDSkip Posts: 14,555
    Are you sure you aren't tripping the polyswitches? I can hear mine cut in and out.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    You missed the sarcasm obviously. The guy that mentioned the mods to the Rta15, was making mods based on wrong information. That was the point.
    The Polk engineers did know what they were doing with the Rta15 tweeter and crossover. Member Decato was just guessing.
    B+W-
    Epos-
    Infinity-
    Advent-
  • heiney9heiney9 Posts: 23,718
    K_M wrote: »
    Nightfall wrote: »
    Many, many things are re-engineered 20-30 years later by tinkerer's. Bean counters and lack of materials is usually the reason. All designs are compromises. 20-30 years later many times the compromises can be fixed or atleast updated.
    This is a very normal life cycle for a myriad of products that are older. As technology gets better, costs come down........it's natural to want to "improve" old things sometimes, even if they were cutting edge in their day.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Pass Aleph 30 | EE Avant Pre | EE Mini Max Plus DAC | MIT Shotgun S3 | MIT Z P/C's | updated SDA 1C| SQ Box Touch/Welbourne Labs P/S- Tubes add soul!
    edited April 2017
    heiney9 wrote: »
    K_M wrote: »
    Nightfall wrote: »
    Uh no. The guy with that mod thread, based all his mods off of things he assumed were true. He even said he was only making assumptions. Simply guessing.
    He did not measure the impedance or frequency response of the speakers he was using, but guessed at what they might be......
    That alone is the reason it most likely was not done by Polk.
    Polk engineers for sure measured the response and impedance and designed a crossover taking all of those things into the calculation.
    His changes were made based on using very old caps that most likely were bad, and assumptions that were never verified.
    B+W-
    Epos-
    Infinity-
    Advent-
    Brian (Decato) did take measurements and posted charts in his thread.
    I will go back and look again, when I have time. I remember reading him saying he was kinda guessing, and saying he did not measure impedance or response.
    Was it later in the thread? in the beginning he admitted he was kinda guessing.
    Im not bashing him or his work it seems reasonable, but perhaps not totally necessary for "sure" is all.
    B+W-
    Epos-
    Infinity-
    Advent-
  • wolfie62wolfie62 Posts: 22
    Hmmm.
    "Polk engineers for sure measured the response and impedance and designed a crossover taking all of those things into the calculation.
    His changes were made based on using very old caps that most likely were bad, and assumptions that were never verified."
    There ya go....an assumption. You assume since the caps are "old", that they must be bad. I just measured the caps in my 1989 RTA 8Ts. All still good and within tolerance. Equivalent DC resistance still good. No mods have ever been done on these.
    I would like to see test results of the SL2000 tweeters' 5 kHz response spike. Can anyone provide a link?
    Invention is the mother of necessity.
    "The Vintage Square":
    Polk RTA 8T (1988, new to me 2018), Peerless+MB Quart DIY (1992), Velodyne DLS 3500R (2005)
    Dynaudio DIY tower 1994: Dual 28 mm soft dome tweeters, dual 9" woofers, custom equal-compromise 2nd order CO, 1.35 cu ft enclosure
    Denon DP45-F (1981), JVC QL Y5F (1980), ADC XLM MKIII (1982), Shure V15V (1982)
    Sherwood S9600-CP (1981)
    Aiwa ADF 780 Cassette (1988)
    Custom DIY dual monoblock 235 w/ch IGBT output power amplifiers
    Those that don't know don't know that they don't know.
  • pkquatpkquat Posts: 558
    wolfie62 wrote: »
    You need to remove caps to properly measure them as I recall. How a cap behaves for different audio frequencies can vary. Electrolytic caps do age. There are plenty of electronics articles about this out on the web, and not just related to audio. Old caps can have effects on general electronic equipment and cause them to go out of spec because the cap does not behave the same at a certain frequency even though it may measure within tolerance at a specific measurement frequency.
    Somewhere a while ago I saw a graph, but I have not been able to find it. Its been mentioned in a couple of magazine review articles from back in the day. They heard and measured the 12-13KHz spike / bump. I am not sure if graphs were provided. Many people including myself have heard it, and its been discussed at length.
    pkquat wrote: »
    wolfie62 wrote: »
    Its in the Stereophile review of the Rta11t speaker.
    B+W-
    Epos-
    Infinity-
    Advent-
Howdy, Stranger!
