Setup question
This may not make sense but thats ok, cause it me.
I'm probably picking up a vintage receiver to use at my office, not with speakers but with my DT-770's to listen to FM radio and feel the nostalgia along with seeing the pretty silver shine and glowing lights...
Here is where my question and ignorance comes in.
Would adding a tube buffer be a possibility in this setup, how would I hook it into the setup, and would it actually do anything?
In vintage stereo receivers is the headphone amp circuit separate from the speaker amp section all the time, part of it, etc.
I "could" add one of these to allow me to use the actual speaker outputs to drive the headphones rather than the headphone plug on the receiver.
  • nbrowsernbrowser Posts: 7,153
    edited January 2017
    That little box looks interesting but you could make your own umbilical cord to accomplish the same task. That said, that little device would require a common ground amp/receiver as well...just something to consider as both grounds would be connected to one portion of the barrel on the headphone jack. Doug could probably make one too...just remember to not go bonkers with the volume control!
    I used to have a vintage Kenwood KR-2300 years ago (would LOVE to have another one!) and it's headphone jack output wasn't too shabby. Remember back in the day they actually put effort into the older stuff to sound better than the stuff made today.
    Just my two cents.
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
  • EndersShadowEndersShadow Posts: 15,067
    Yeah I think I may start with just the unit and my headphones.... From there I may go a bit crazy and add a set of custom overnight sensations with a voxel sub at a later date just because, but I bet it would look and sound good as is......
    If I end up with it I will post some pics... Its a GORGEOUS looking unit and the price is right :smile:
    Good idea, why spend all the money at first, go simple and see, then build if you too. If need be...let is "snowflake" out, so to speak. :)
    edited January 2017
    Step one. Totally forgot to bring in wire for the FM radio section but it's still pulling stations, just really low level.
    Also plan to bring in my TT and put it on top of it to spin LPs....
    Mainly just because :smile:
    Master chief approved @mrbiron
    @mhardy6647 I figured you would appreciate this will all your vintage knowledge. You will notice the button on the side... that was a modification to fix the turn on problem most of these had where the relay in the loudness (ie Volume) switch would go bad and not turn on. Rather than fixing it, many people just added in their own power button, which is what was done here. I may eventually replace it with a more flush toggle button, but for now its kinda a fun talking point.
    Its like my Sherwood has a turbo boost button :smile:
  • mrbironmrbiron Posts: 4,557
    I do NOT approve of you hiding his evil, less handsome twin behind the Sherwood!
    Wish i was allowed to wear headphones at work. #idgetfired
    Why do they make cube walls so ugly :p
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Reduction & Crack w/Speedball
    mrbiron wrote: »
    I will post a better pic later. I moved some things around a bit lol
  • ZLTFULZLTFUL Posts: 4,226
    I guess it just seems like a clunkier and more cluttered way to solve a problem...
    I have (and still do) thoroughly enjoyed my Little Dot running from my phone. Sound quality is surprisingly good and the smaller amount of gear keeps my desk uncluttered...or I guess leaves me more room for Funkos. Hehe
    Still, a good looking receiver though.
    2 Channel: Silverline Audio Sonatina MKI, Monitor 5 Series II, DIY Seas based bookies
    LR 2 Channel: LSi7, DSW-MP2000
    HT: JTR Triple 8 LCRs, DIYSG Volt 8LX Surrounds, DIYSG Volt 6LX Atmos, 6 SI HT-18D2 Subs
    Guest BR 2 Channel: Swans D1080MKII
    Deck: Pyle BT Speaker pair with upgraded woofers
    ZLTFUL wrote: »
    I ABSOLUTELY agree... however it wasnt purchased to really solve a problem, but purchased because...
    ZLTFUL wrote: »
    I bought it to do just that basically. Plus I dont do Funkos... yet lol....
    And I've got a bunch of space I could readjust for other things.
    Right now its cluttered as I've got the computer Ricardo is picking up next to it, then dual monitors, then my laptop dock/etc...
    Next week I it will look much better.
    But as you said, I bought it because the faceplate called to me.. and then made it solve a problem I didnt really have lol...
    Because @mrbiron made fun of me :wink:
    Better, but i have to question the authenticity of the photo when Mr. Vader is sporting May 4th as a date.
    Because.... May the 4th.... be with you :)...
    Ahhh....I got out geeked....a line has now been drawn in the sand. If you accept this challenge, know there will be many lives lost.
    mrbiron wrote: »
    Kinda like the number of times you die when we played Halo 5 :wink:
    Which is a LOT!
    Name the day and time...I've still got legendary
    mrbiron wrote: »
    Which is a LOT!
    Soon as I need to beat it co-op on legendary too
    How to out-geek anyone in geekdom...
    How many times does Dr. Daniel Jackson die in the series, Stargate SG-1?
    ZLTFUL wrote: »
    Depends on your definition of die lol....
    He has a couple times ascended which could be considered death.... or dies and is brought back to life....
    So define dies lol....
    PS I HATE YOU RIGHT NOW LOL... You know the right buttons to push.
    Boy am I glad I've never seen a single episode.
    Read the book, watched Kurt Russell in the movie, and beat the Sega video game.
    Phew! I need another beer.
    I'm on my third and there will be more as I just found out Stargate SG-1 is NOT on Netflix anymore :disappointed: .....
    I had the TV to myself with the kids and lost the ability to binge watch it....
    In other news @mrbiron...... wanna Xbox RIGHT MEOW?
    Geeks! lol.
Howdy, Stranger!
