PSW505 Popping sound changed to a heartbeat and static noise
I have two PSW505 Subwoofers. two weeks ago I noticed one of the subs making a popping noise which quickly changed to no sound except for static and a heart beat sound that doesn't stop even when the input is disconnected. Now the second sub is starting to make a similar popping noise but it's sporadic and the second sub is still working. Seems strange that both subs would start having issues within a few weeks. I haven't made any changes to the audio system other than adding an xbox to the receiver. Any ideas what has happened to these subs that are only two years old with moderate use?
Best Answer
Answers
  • Thanks for the advice. yesterday the second sub stop working also. I will contact Polk CS during the week. I hope your right about the warranty. I have been very impressed with these subs until now.
  • Before I start scoping my PSW505 amp for the "heartbeat" problem (without the aid of a schematic) I'd love to hear from anyone who saw the previous post and has since "been there, done that" with a possible fix.
    Applying power triggers a regular heartbeat thump at about 2 beats a second. The beats gradually slow down until they are replaced by bursts of static. The static stops after a few seconds and then the unit works perfectly. Switch the main power off for a few minute and then back on and the amp behaves normally unless left off for some time.
    The problem does not happen after the unit wakes up from standby, but it's only going to get worse. The unit is out of warranty. Polk declined my request to release schematics. They would be happy to sell a replacement amp but I'm guessing the price would be about the same as the current closeout price for a brand new unit.
    These were not the answers I'd hoped for, but at least I was able to navigate Polk's relatively straightforward AVR and connect immediately with a polite human that I could understand!
    I did find a post suggesting the Klipsch RW-12 amp is a close relative and located that schematic. The designs appear conceptually similar but the Klipsch is too different to be of much use. Both the Klipsh and early PSW505's incorporate a Bash board, so it may be that earlier units are a closer match. Thanks for all help!
  • FestYboy
    FestYboy Posts: 3,861
    Start at the power supply, specifically the rectifier circuit and the caps associated with it
  • GrahamW
    GrahamW Posts: 3
    Thanks FestYboy, you make the logical suggestion but the power supply checks out perfectly. The problem turned out to be electrolytic capacitor C14 on the amp board (22uF, 50v, 105C). The capacitor had been mounted in physical contact with an adjacent 1W resistor that probably runs hot enough to dry the capacitor out prematurely.
  • FestYboy
    Thanks for the tip, I currently have 4 and am waiting for one to give up on me... Was expecting something more dramatic, but it seams like it's just a matter of poor component placement that can easily be rectified.
  • GrahamW
    GrahamW Posts: 3
    Cough; the initial claim of victory proved premature (like - that's never happened to me before!) After leaving the unit without power overnight, a slightly different popping resurfaced, albeit for less time before the unit started working.
    So ... I removed the remaining seven small electrolytics from the amp board and checked them with a capacitance meter. All were low, only the 330uF and two of the remaining five original 22uF's were within the usual -20% low end spec. All others, including the 10uF 50v, were off by as much as -85%.
    Capacitors must be lifted to check them, so it takes no longer to simply replace old with new. That's what I did and would advise others to do. The 330uF 16v (adjacent the PCB mounting bracket) could probably be left alone, but I had one on hand and threw it in for good luck.
    The unit sat without power overnight and behaved normally when first powered up today. Fingers crossed!
  • bitNine
    bitNine Posts: 2
    GrahamW wrote: »
    YOU ARE MY HERO! I latched on to this thread about 5 months ago when mine, about 4 1/2 years old, started making the same noises. I was able to get it to hobble along until today when my wife finally started complaining that it wouldn't stop making the stupid noises. So, out came the rear assembly and I pulled it apart to get to the amp board. The whole time my wife is in the corner naming new subs I could get. "NO, I'm fixing this thing", I said. Thankfully I had a capacitor kit with the 7 necessary 22uF 50v caps, and replaced them all without any hesitance. BAM! Working good as new. Thank you, thank you, thank you, thank you, thank you! I also did not touch the 330uF cap even though I had the replacement.
  • Yes, thank you for the tip!! I just replaced all 7, 22 uF caps and it works great!! Thank you! I also didn't have to touch the 330 uF caps. Only cost me 5 bucks to fix, bought the caps off Amazon.
  • Went to use my PW505 for the first time in a couple months and the power light is barely on and can’t get any sound through it. I checked the fuse and it appears to be fine. It’s about 2&1/2 years old and I don’t use it all that often.
  • From your post you should be covered under the warranty, telephone Polk at: 1-800-377-7655.
  • Been a little over 2 years since I replaced all the 22uF caps on my amplifier. A couple days ago we got some new furniture, so everything in the family room got disconnected. When I reconnected the sub, I Noticed the switch was in standby, and LED was solid RED. As soon as I switched to auto/on, the LED went green, then slowly faded away until it shut off. I fiddled with it for a couple minutes until the LED would not come on any longer. I left it in standby, and came back 15 minutes later and it was on again. Flipped on the switch and it started working again. Not sure what to do, but I might focus on the 330uF cap to start.
  • bitNine wrote: »
    What capacitors should I get off amazon? Mie JSUT started doing this after 4yrs and 3months.
