Adding 2nd Cross Over board to SRS
I have a pair of the 8 woofer, 4 tweeter SRS's with the big and little blade interconnect. I'm in the process of rebuilding them. They are not a basket case presently however. I need to add a second crossover deck above the original one in order to gain more real estate for the bypass caps. I've seen this done by replacing the original 4 nylon clip mounts (that mount the original board) with risers so that they run through the 4 holes on the original board and continue up another 1.5" or so so that another thin board can be mounted to make a 'double decker' layout. I need some tips on how to attach the risers to the 4 holes in the inductor because on the back side of the holes is the inductor wire! So how do I get something to stick down in the little hole? Nylon all-thread maybe? Advice appreciated!
