Any help for my Sony C222ES SACD player
Dabutcher
in Electronics
Always worked great. Now drawer will not open or play anything? Any thought before permenant retirement? Thanks. D
The belt could stretched out, even broken or it's possible a CD is jammed inside. Take the cover off to inspect.Political Correctness'.........defined
President of Club Polk -
yup what F1Nut said. These have belts or plastic gears that wear out. Could be an easy fix.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
Thank you. Peace. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Opened it up and removed the four discs. The fifth one was locked into cd transport spot. Figured how to release it . Player opened and closed ,then locked up again. Loved this player. Oh well,time to retire. Thanks for the help. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Could be a bad belt, could be a bad optical pickup......
Does the tray spin around to each disc location looking for a CD to read after it closes?Political Correctness'.........defined
This would be my guess as well (the belt, that is) -- cover's easy to remove & the little drive belt is easy to see/get to (at least on the "normal" Sony CD changers).
The Yamaha changers have this problem, too. I have been known to fix those, temporarily, with small rubber bands -- and, no, I am not proud of that.
