Safety Receptacle...
scubalab
scubalab Posts: 3,101
edited December 2016 in Electronics
My A$$!
So, I went to plug something in by the window seat in our living room (fairly new with new receptacles and lighting) and had a nice little surprise. At the time I wired these, all I could find at Lowes were some Decora "safety" receptacles. Well, they SUCK!
They have this spring-loaded "guard" that only allows a plug (two prongs) to slide in and is intended to keep kids from sticking other things in there (think Heiny9's avatar...). They make it very difficult to plug things in and you have to force the plug in.
So, back to story - This afternoon, when I "forced" the plug in, it wouldn't release the safety guard and the whole frickin front of the receptacle popped off and completely exposed the inside of the receptacle! How's THAT for safety Cooper Electric?
  • lightman1
    lightman1 Posts: 10,776
    :o:o Get the Leviton receptacles. Better build quality. I've used them for about 30 years. Turn the breaker off, Al !!!
  • scubalab
    What's a breaker?!?
    Wuss
    heiney9 Posts: 25,053
    I ain't afraid of no receptacle
    F1nut Posts: 49,711
    scubalab wrote: »
    My A$$!
    Wow!
  • Willow
    Willow Posts: 10,862
    We have those in our house, all new houses do. While I see their potential after sticking things in them over and over they get loose. (Pervs enter comments here) so kind of pointless. In your case that is just awful.
    pitdogg2 Posts: 24,481
    lightman1 wrote: »
    Turn the breaker off !!!
    Pffft sissy...... :p:p I ain't afraid of no 120v. But if you stand in water it sure makes it exciting ...
  • mrloren
    mrloren Posts: 2,454
    This was 3 weeks ago, kids always plug and unplug the hair dryer and crud in their bathroom. Screw worked it's way loose over time
    Nasty wires but wonder why it's not ground fault in a wet area ? Is the circuit it's on tied into GFI?
  • lightman1
    It should be fed from a GFCI upstream. Line/load set up. Looks nasty @mrloren.
    Hair dryers and heat loads wreak havoc on receptacles. That should have been a 20A rated receptacle.
  • lightman1
    And BTW, pitt...I got you sissy right here buddy.
  • mrloren
    lightman1 wrote: »
    well it is grounded and it is a GFCI circuit. when my son was 5 he wanted to wash out the hair dryer one day. breakers and GFCI all tripped before the hair dryer fried.
    I went to Home Depot and the same replacement was 68 cents... The guy said to get the premium ones for like $2.50each. I replaced all bathroom and kitchen receptacles with those. Premium one weighted 3X more than the cheap ones the builder put in. MLK weekend a Friend is coming over to replace the rest in the house. wonder if it will make my stereo sound better?
    lightman1 wrote: »
    I know you do Tiny..... :p:*
  • lightman1
    lightman1 wrote: »
    What's your address?
  • Once again, Al, life imitates art. :o
  • scubalab
    You know Mike, that happened literally minutes after I saw your Wilco Schmilco post in the "What are you listening to thread"! Where do you hide your crystal ball?
  • scubalab
    All better now! Home Depot had Leviton - thanks for the advice Russ!
  • lightman1
    Top notch work, Al. Now trim out that window, slacker......
  • scubalab
    Ah, it's been without trim for about 6-7 years now. I think I'm procrastinating because of something my grandfather used to say... "The day you finish working on your house is the day you die.". I may be misinterpreting that quote, but I'm sticking with it!
    And, the trim matches much of the rest of the upstairs, so it's all good! :p
  • polrbehr
    polrbehr Posts: 2,825
    mrloren wrote: »
    Ouch, for a second there I thought you had aluminum wiring. :o
    I had a GFCI in an approved outdoor enclosure do almost the same thing.
    Nothing like the aroma of fried electrical insulation too, maybe they do that on purpose so you know if there's a problem brewing?
    lightman1 wrote: »
    lightman1 wrote: »
    You know I love ya Russ...3 hrs. south of Tonyb
  • lightman1
    lightman1 wrote: »
    lightman1 wrote: »
    Awwhell! I'll be in Lafayette, Indiana next week. What say you?
    EndersShadow Posts: 17,517
    lightman1 wrote: »
    lightman1 wrote: »
    lightman1 wrote: »
    He's in Bloomington-Normal, IL so you guys are 2 hours away from a hugfest :smile:
  • kharp1
    kharp1 Posts: 3,453
    mrloren wrote: »
    This is a good example of arc fault. New code calls for arc fault breakers in berooms due to wires coming loose and arcing in areas where people are sleeping. Far more common than people realize. If you're comfortable with such things I highly recommend powering down and checking all the wires in your house once a year. If you do attempt this I suggest using a torque driver, or call a pro.
    Post edited by kharp1 on
  • lightman1
    lightman1 wrote: »
    lightman1 wrote: »
    lightman1 wrote: »
    Only if you join us, Dan. Wouldn't be the same without you. ;)
    Dang Dan just fink me out to the sparkie :p
    One of these days Russ..fo sure
  • lightman1
    kharp1 wrote: »
    mrloren wrote: »
    Good call, K....especially the ones wired with 12ga 20A circuits i.e. kitchen, dining room and bathroom circuits. They are side wired like the one pictured above. Load causes heating and cooling of the set screw terminals thus potentially loosening the contact between wire and terminal. Leading up to the near disaster you see.
    Have a qualified tech check and service these problem outlets. Anything that handles a heating, cooling unit. Motor loads, refridgerator-freezer etc pay more attension to.
    Peace of mind, folks.
  • mrloren
    kharp1 wrote: »
    mrloren wrote: »
    When this happened I called a contractor friend, he told me it was common and to just replace it. My wife was a little freaked so she called an electrician, guy told her before he comes out it would be $175. I then went to Home Depot and did it myself. It's not hard to do just make sure the breaker is off and check it with by plugging something in. I got a tester for like $4 to make sure power was off.
