Loctite Power Grab All Purpose replacement?
pkquat
I just saw this was no longer made. I've used the Express and I don't like it. Any other recommendations for gluing magnets? Any recommendations for sealing or adding additional bonds to cabinets? Liquid nails should work, but its tough to get a good fillet, and cleanup is not as easy.
For gluing magnets, a 2-part epoxy works extremely well.my 3.1TLs
I will fix your shifted magnets for free. -
Wait what???? It sells it works good and cleans up easily....So discontinue this.....WOW!!
Two part epoxy works great, but what @pitdogg2 said. It seams all the competitors are similar to the powergrab express now. Quick set times in 15min or less. From what I read hear and online the changes were for less VOCs and faster set time.
I'm hoping someone found an alternative that works as well as the original, and cleans up as easy. -
There's a multitude of different PowerGrab formulations. And in the end, they're just construction adhesives. There's a whole isle of construction adhesives at the local HomeMenLowes.
http://forum.polkaudio.com/discussion/170827/loctite-henkel-power-grab-for-speaker-magnets#latest
For the record, the Power Grab was selected based on having no trace of silicone in the formula. The specific item was listed in that link. It's still available from Home Despot, at <$5 for a six-ounce tube.
Power Grab has many advantages over epoxy for this application. It's water based, so clean up is easy. There's no mixing and the open time is longer making it much easier to work with resulting in a nice smooth bead for a professional look. It should also be much easier to remove if necessary.Political Correctness'.........defined
President of Club Polk -
So what's the deal with this? Is the formula we prefer, indeed, discontinued?
Or is Express okay? Looks like it's still available.I disabled signatures. -
You can still find the original clear, all purpose.Home Theater/2 Channel:
dhsspeakerservice.com/ -
@westmassguy Where can you find it? I thought you said it was no longer available in another thread from last spring or a year ago. Lowes did not have the small 3oz squeeze tubes, which was the only non-express listed online. The guy said he hasn't seen it a while. I'm not sure if it is the same stuff. Amazon may have that 3oz size. There is a 2pack 10.4 (free 15% more) listed that looks right, but the single pack of the same switches to a picture of the express, so I'm not sure. Some others are outrageoulsy priced or its a poorly listed bulk pack.
You can order it online. Found it on fleabay, and some other sites that still have stock.Home Theater/2 Channel:
I'll check fleabay. Just have to check that they are not swapping it with the Instant stuff because "Its the loctite replacement for it".
Thanks -
Make sure it's the clear, all purpose: http://www.ebay.com/itm/Loctite-6oz-Clear-All-Purpose-Power-Grab-Interior-Construction-Adhesive-2029846-/132022359065?hash=item1ebd255419:g:xckAAOSw44BYChsjHome Theater/2 Channel:
The picture shows the Express verion with the 0 seconds Instant Grab. I thought the Express is the new stuff. I've used the white Express version. It seams drier, and seams to tack up quicker. Its tough to get a smooth bead, and it doesn't wipe off my fingers as easy. Maybe the clear version is different. The non Express version was easier to work with IMO. It felt more like a caulk.
Is the clear express version easier or should I still be looking for the regular all purpose? -
Local Home depot and Menards still carry it here.
Sad news I love that stuff. I think I still have a couple of tubes laying around.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
