3.5 on Hinge Headphone?
Could someone please tell me, the spec's for the hinge headphone audio cable is a common 3.5mm. The hinge headphones is have (that I lost the cable for) is NOT a 3.5mm. It is much smaller. What is it and where can I get a replacement.
  • KennethSwaugerKennethSwauger Moderator Posts: 6,129
    The end of the cable that plugs into the source is 3.5mm, the end that plugs into the headphone itself is 2.5mm. Polk will probably send you a replacement cable if you call them at: 1-800-377-7655 select option 2 for parts.
    "Passion is inversely proportional to the amount of real information available", G. Benfield
  • Thanks very much. Any idea why they would not stick to a standard 3.5 cable? How inconvenient.
    You're welcome! I'm afraid I have no idea, sorry.
Howdy, Stranger!
