Soundbar Subwoofer Connection
kjalfred
I have a Polk Surroundbar SDA and the soundbar doesn't keep a connection with the subwoofer. I have a constant blinking amber light and the sub has an amber light as well. The speaker itself works but no subwoofer connection. I followed all the owner's manual instructions (shut both off, turn back on, checked to make sure they were both on the same channel) and I also shut off my internet modem to see if it was interfering with it but it's not. It's worked fine for years so I don't know why it would just stop. The sub's only about three feet from the soundbar.
Hello,
Welcome to Polk's forum. It's probably a good idea to contact Polk's CS department at: 1-800-377-7655 select option 1.
Regards, Ken -
Will do. Thanks!
Does anyone at Polk ever pick up at this number?
Finally got through to Polk. Guess the SDA's are ancient history. Looking at the Magnify1 system. Any thoughts on that one? Looks pretty good for the price ($250) at Best Buy.
