Question about 8" woofer
timber0472timber0472 Posts: 5
edited November 2016 in Car Subwoofer Talk
Hey guys I'm a newb so forgive this odd question but I have a 8" dvc polk sub that is going in a harley tourpak. I have it in a subwoofer box now but I was curious if it needs to be in a box. I understand that if it's out in the open that the required air space is necessary but the way I have it set up now is a box inside a box... Could I just build a small support for the sub since it's inside a "ported trunk?" Thanks for any advice.
  • You won't get the most out of the subwoofer. Each sub is created to be put in a specific box with it you will get less than optimal performance and even might damage it. I would keep it in a box or get a low profile box at a minimum to keep performance up.
    Living room
    Mains: Paradigm 90P
    Lows: Velodyne CHT12, Pioneer SW-8Mk2
    Power: Marantz SR7000
    Tv: Samsung UHD 55' Curved 4k
    2 Channel Den
    Mains: SDA2B Upgraded XOs and Binding Posts
    Pre: Denon PRA-1200
    Power: Yamaha AV34
    TT: Pioneer PL510
    Tv: Samsung UHD 55' 4K
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Little dot 1+/GE JAN 5654w
    Closet of Dreams:
    Harman Kardon AVR130
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    New Large Advents 25th Anniversary Edition
    Bravo V2/RCA Clear top Conn branded 12AU7
  • K_MK_M Posts: 1,015
    I never understood the idea of trying to listen to music, on a motorcycle. The bike itself is far too noisy, and wearing a helmet limits sound a lot, and wind and being in the open limits it even more....
    Lsi15, Lsi9, LsiC,Rta11t,M5jr+,M4,SDA 3.1TL, SDA SRS 2.3TL, Rti6....Still listing stuff, a work in progress.
    B+W-
    Epos-
    Infinity-
    Advent-
Howdy, Stranger!
