Is this forum the only way to get help?
I have a dead soundbar that I got back in April. I can not get through to customer service; it's been a steady busy signal for the last hour.
  • [Deleted User]
    Hello,
    Welcome to Polk's forum. Polk's CS department is at: 1-800-377-7655 select option 1. I just wanted to make sure you had the correct number.
    Regards, Ken
  • nhhiep
    nhhiep Posts: 877
    yep. it looks like the whole department is on vacation. I've issue with my order. I've been calling, emailing, and posting it here. No response from them and phone line is dead.
    Compare to SVS and other ID brands, this is a major disappointment.
  • rooftop59
    rooftop59 Posts: 7,981
    Yea I have to agree. Website is a mess, and it's difficult to reach CS. Not good for a large company trying to keep competitive in this market especially when smaller ones seem to keep up much better...
    Game Room 5.1.4:
    Bedroom 2.1
  • [Deleted User]
    Polk's CS department are experiencing some telephone technical difficulties, but the IT guys are working on it. Be patient and things will be back to normal.
  • waiting
    On Dec. 8 I tried for an hour to get through on the phone. I ended up sending an e-mail and got a quick reply assigning me a case number. But now it's been almost a week and still no response from a CS rep. Do they really have a CS department?
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited December 2016
    I'm with you on this issue. I have owned Polk products for a long time. I have contacted them on several occasions over the years and their cs was second to no one.
    However, my psw505 inevitably gave up the ghost over the weekend. So this morning I tried to call them for a replacement amp, being that it's still under warranty and was on hold for a long while with no answer. When prompted to leave a name and call back number, I followed the instructions and successfully submitted the info. Low and behold no-one ever called.
    It's frustrating, I love the brand but this needs fixed.
  • [Deleted User]
    If you're fairly handy with a screwdriver you can unplug the subwoofer's AC power cord and remove the screws that go around the circumference of the amplifier's input plate. Then use a putty knife to loosen the amp from the cabinet and pull it away. You'll see a red wire and a black wire leading from the amp to the 12" woofer, disconnect these from the woofer's terminals. Package up the amp and send it to: Polk Service, One Viper Way, Vista, CA. 92081, include a short note giving them your name, address, email address and a copy of your sales receipt. They'll quickly either repair or replace your amp.
    I hope this is helpful.
  • jeremymarcinko
    Thanks Ken. I'll do that.
    F1nut Posts: 49,802
    waiting wrote: »
    Yes they do and they are trying their best to keep up, but are under staffed and completely overwhelmed right now. Give them a bit more time and they will get back to you.
  • waiting
    My issue is that when opening the box containing a new soundbar, the digital audio cable that was supposed to be included was missing. My e-mail requested that they send me the missing cable-a very simple request. Today I received another form letter e-mail saying they've had a high volume of calls and e-mails in the last two weeks and suggesting I try calling again.
    My issue is one that can easily be resolved by e-mail but apparently they didn't read my e-mail to realize that. I did try calling again today but gave up after almost 30 minutes.
