I need a CD player in Indy
Hey guys. I broke out my cd's and I'm now in need of an inexpensive CD player. I've been listening to flax for some time but it can be a pain with the squeezebox duet. I know inexpensive can be relative to a lot of people but something near 100 bucks would be great. I'm in Indianapolis so anybody close would be especially great :-)
Thanks!
David
I like to listen, tinker, listen and repeat.
  • ken brydson
    ken brydson Posts: 8,647
    edited November 2016
    What's the rest of your system? If you don't need anything fancy any cheap CD player or DVD will work. Probably pick one up at Goodwill for next to nothing...
  • Bigbang
    Bigbang Posts: 233
    Honestly. That's what everyone say until they go to a goodwill. I'm looking for something that has been taken care of and not trashed. Thanks for your reply.
    EndersShadow Posts: 17,527
    Bigbang wrote: »
    Why not just buy a cheap DVD or blu Ray player? Those can be found NEW at frys for around that and they will play CDs too
  • rooftop59
    rooftop59 Posts: 7,968
    Accessories4less has several for $20-50 over your budget, brand new or refurbished with warranty. That might be ur best best for a dedicated CD player.
    I will say that it my experience the onkyos are pretty flat sounding, but so are cheap DVD and blu Ray players...
    I have also found the duet a little frustrating, but the standard squeezebox much less so, so that's another option.
    Game Room 5.1.4:
    Bedroom 2.1
    tonyb Posts: 32,906
    I have a Pioneer BDP 320 collecting dust, it's a BDP but does well on cd's also.
    mhardy6647 Posts: 33,021
    If none of the above works out, PM me and I can send you one from the stockpile in the basement for the cost of postage.
    fine phalanx of odds & ends downstairs.
  • indyhawg
    indyhawg Posts: 1,636
    I have a couple I am not using. I sent you a PM. Let em know if you are interested.
