Connect Blu-Ray player to AVR or TV?
acmf74
acmf74 Posts: 936
I just recently picked up a NAD receiver. I have the option to plug the Blu-ray player to the AVR. Are there any benefits going this route or just going directly to the the TV?
Thanks,
  • rooftop59
    rooftop59 Posts: 7,981
    You can only get the lossless codecs like Dolby trueHD if you go through the avr. And even if you only have a modest surround setup, you will notice a pretty distinct difference in clarity, separation, tightness and weight of the bass, etc.
    So yes, run it through the avr...
    Game Room 5.1.4:
    Bedroom 2.1
  • Willow
    Willow Posts: 10,878
    It also makes it easier if running more than one HDMI cable device. Many into the receiver and one out to the tv
  • andrew82
    andrew82 Posts: 144
    Definitely run it through the AVR. In addition to the benefits already mentioned here, it looks a heck of a lot cleaner (in most setups).
  • acmf74
    acmf74 Posts: 936
    Ok. Will do the AVR route. Really looking forward to hearing the difference.
    Thanks for all the replies.
