WTB: Sub Cable
EndersShadow
Looking for a low cost sub cable. Not sure how long I need so just shaking the trees to see whats around. Probably something around the 8-10 foot range or longer would be preferable....
Had a Audioquest Black Thunder cable at one point I really liked so debating going new with one of those, or a Blue Jeans Cable LC-1...
But wanted to see what you hoarders have in your cable stash you might be willing to part with...
did you see these Dan
http://www.audioadvisor.com/prodinfo.asp?number=PGICCAS&variation=3
I found them while looking up the diff between the Mamba and Thunder cables which are the very same cable pretty much -
So your saying the Mamba and Thunder are the same, or the PANGEA and the Thunder are the same?
For longer lengths the Pangea looks to be a winner for sure."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I have an audio quest with a blue jacket not sure what model number? It's at least 15 feet maybe more I can measure when I get home tonight if you're interested.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
EndersShadow wrote: »did you see these Dan
So your saying the Mamba and Thunder are the same? yes that is what I'm saying
Sounds like Rooftop also has the same wire that Mamba and Thunder also use just with the audioquest braid.
Pangea gets all their copper from Cardas. The very same copper Cardas uses from my understanding.
Dan- I have a BJC LC-1, 12 ft. If you are interested.
I may just take that off you.... PM me what you want on it."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
think @indyhawg has me covered at least initially with a 12 foot LC-1 cable."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Still in the market....12ft is too short at least initially... Will see what happens once my stands come in.
May position the sub between them in which case it should work fine.
Anyway, if you've got something ~20 feet or longer let me know."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
make one from Canare L-5CFW good stuff
http://store.haveinc.com/p-54689-canare-l5cfw-hdsdi-coax-flex-bla.aspx -
I have couple of monoprice sub cables and will check the length tonight. Let me know if that will do. If yes, send me your address via PM and you can have it for shipping cost.
