Polk Sound Bar source changes by itself
For some reason our Polk 3000 will change sources by itself. Such as it will go from source one to 2. Any ideas on why this happens?
  • Hello,
    Welcome to Polk's forum. I would erasing any instructions that are in the programming, do this by placing the soundbar in the "standby" mode, with the LED red. Then, touch the "learn" button for about 2 seconds and the LED will blink. The soundbar should now only respond to the supplied remote. If it no longer changes sources then use the TV's remote to program the remote functions.
    If you are still having a problem, give Polk's CS department a call at 1-800-377-7655 (select option 1) on Monday.
    Regards, Ken
