Capacitors and resistors where to buy or buy from you for SDA-SRS2
VSAT88
Please sell me two used/new 4.4 uF good quality caps or tell me where to buy. I would like Clarity Cap really. These will be used in my SDA-SRS2 speakers. I would take two 12uF's as well so I do not need to rob them from my SDA2b's. I would also like to purchase two 7.5 ohm resistors (Dale resistors or similar) as well as the 2.7 ohm resistors for the high side crossover network. I have jumped out the Polyswitch and some recommend the 0.1-0.5 resistor in that position so I will buy that too if needed so..
Two 4.4uF
Two 12uF if possible
Two 7.5 ohm
Two 2.7 ohm
If recommended two 0.1-0.5 resistors
Hey Thanks !!
Two 4.4uF
Two 7.5 ohm
Two 2.7 ohm
Hey Thanks !!
Many places to buy get your Google on. Try parts connexion.
Madisound carries Clarity, as does Parts Connexion. You'll need two 2.2uf caps in series for the 4.4uf, if sticking with Clarity.
Sonicap has the exact values.Home Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »Madisound carries Clarity, as does Parts Connexion. You'll need two 2.2uf caps in series for the 4.4uf, if sticking with Clarity.
In series, or parallel? I think you mistyped?
http://www.allaboutcircuits.com/textbook/direct-current/chpt-13/series-and-parallel-capacitors/
DollarDave wrote: »westmassguy wrote: »Madisound carries Clarity, as does Parts Connexion. You'll need two 2.2uf caps in series for the 4.4uf, if sticking with Clarity.
Which one would you go with. I got Clarity cap last time and they seem to be pretty good.. -
I prefer Sonicaps, but the Clarity ESAs are excellent as well. Sonicaps are more musical, a tad warmer to my ears, while the Claritys are more forward, in your face.Home Theater/2 Channel:
Parts all ordered from Parts Connexion. Gonna use the Clarity Cap again. Liked them last time so that's where we will go again. Using Dale resistors . Don't know why I did not recall that I could use two in parallel. Thanks for rattling my brain around. Maybe I can remember that next time. I sure thank you for being so helpful westmassguy.westmassguy wrote: »Madisound carries Clarity, as does Parts Connexion. You'll need two 2.2uf caps in series for the 4.4uf, if sticking with Clarity.
Sonicap has the exact values.westmassguy wrote: »I prefer Sonicaps, but the Clarity ESAs are excellent as well. Sonicaps are more musical, a tad warmer to my ears, while the Claritys are more forward, in your face.
