Another ground loop hum issue
Easy Runnin
I have a 5.1 system in my family room. I also have a 2 channel system in the same room except the speakers are in the living room and basement. There is about 30 feet between each system. Each system is on a different electrical circuit. I run a RCA cable from the zone 2 out on the AVR to the aux in on the preamp. I do this so I can listen to pandora on the 2 channel system. I've been using this setup for over a year without any issues. At least not that I noticed.
A few days ago I switched out the pre amp and amp and now I have a serious humming sound coming out of the 2 channel system. I took out a NAD 304 pre and 2400 amp. I put in a parasound php850 and hca1000.
I've spent the last 2 nights trying to trouble shoot. Here is what I determined:
When I disconnect the RCA cable between the 2 systems - the hum goes away.
When I disconnect the hdmi cable between the AVR and the tv - the hum goes away.
When I unplug the tv-the hum goes away.
When I disconnect the cable from wall- the hum does not go away.
A cheater plug on the tv reduced the hum but did not eliminate it.
What's the next step in solving this puzzle?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
Move the cheater plug to the receiver and see if that helps.HT SYSTEM-
lsi 9's -
Cheater plug on the receiver didn't make a difference.
It's a Samsung plasma TV which always had that plasma hum. Is it possible that has something to do with it?HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
BR - Yamaha CR800/Polk monitor 5 -
Try one of these. I've used one and they work! http://www.parts-express.com/jensen-iso-max-vrd-1ff-75-ohm-inline-digital-catv-isolator-hum-eliminator--246-0121
Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
I was thinking that was the way to go until i disconnected the cable from the wall and still had the hum.HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Seems to me, the new gear is the culprit, did you try cheater plugs on any of the new gear.....pre amp or amp ? Try the pre first.
A good power conditioner may be up your alley also.HT SYSTEM-
lsi 9's -
Easy Runnin wrote: »I was thinking that was the way to go until i disconnected the cable from the wall and still had the hum.
I'm sorry I read your first post wrong. Here's a short article that might help. http://www.psaudio.com/ps_how/how-to-find-and-fix-hum-extended/
Anaheim Hills CA,
Cheater plug on the parasound pre reduced the hum significantly. Cheater plugs on both the pre and amp eliminated the hum. When I switched out the parasound amp with the NAD amp, I only needed the cheater on the pre.
I tried a different HDMI between the AVR and TV. I tried a different I/C between the pre and AVR. I'm using an older used Panamax 4300 that I just acquired on the 2 channel side. I plugged the amp(s) directly in to the wall. Now what? Is there something I should look for or test on the amp and pre?HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Not really, probably just a matter of too many grounds going to one place. If the cheater plugs worked, why go any further ?
Does the Panamax help at all ? Plug the pre into it and see, leave a cheater plug on the amp directly into the wall.HT SYSTEM-
