Speaker Jumper Length
Poolgod69
Aloha,
I hope all is well with you. I am wanting to make some speaker jumpers. Why, because I just want too. What lebgth do you recommend? I am guestimating about 8-10 imches should suffice. Your thoughts?
Brian
Brian
Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes:
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Depends on the speaker cable you use. Some stuff bends easy, some doesn't.Political Correctness'.........defined
President of Club Polk -
I have premade xlo jumpers that are stiff and not much longer than 6 inches. If that.
Happy New Year everyone!
Rather than start a new thread I thought I would piggy back on this one for relevance.
I want to make my own cable jumpers as well and figure 6-8 inches is ideal for my application (depending on flexibility of the cable).
What would be an ideal cable gauge to use for the jumpers?
I have read online that the jumpers should be matched in gauge to the speaker cables but that thought was not universal so I wanted to see what the consensus is here.
Thanks for any feedbackSpeakers
Front - LsiM707, Front presence - LsiM703, Future ATMOS - VS 700LS
Center - LsiM706c, Rear surrounds - 80 F/X LS, VS 900LS. Sub - (pair) Klipsch R-12SW
AVR - Yamaha RX-A3010
AMP - NAD C275BEE
Main HT - LG 4K 75”, Sony UBXP800M2
Bedroom HT - LG 55" 4K, Philips BDP7501 4K UHD player , Yamaha SRT-1500 sound projector, Spare room HT LG 50” plasma, Yamaha BD-671
Office - Pioneer X-CM56, Bose iPod dock
In Storage - 4 - RTiA9, RtiA3, CSiA6, FXiA4, Blackstone TL1
The only source of knowledge is experience. Albert Einstein -
Hell the jumpers I made are less than 4 inches. I dont see any reason to go any longer than distance and flexibility dictate.
consensus here make them out of the same stuff your speaker cable is made out of.
Same cable as your speaker cable and whatever length is required.Political Correctness'.........defined
Keep it simple. Use the same as those connecting your AVR, keep them short as practical.
EnjoySamsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
