Easy solution for loose RCA jack
cortico
I got a few Rean RCA connectors to build a couple interconects, I latter find out that these connectors are much inferior quality when compared with Neutriks. The contact surface finish seems decent, but the ground metal ring is very flimsy, there is no grip at all!! So I came up with this temporary solution using a 9mm hose clamps... I thought I should share
Since they're kerfed I would think you can tighten the grounds up a wee bit with a pair of pliers.
That's what we used to do with loose "RCA" connectors back before the cost of a cable wasn't comparable to the price of a new car
