New AVR or Network player?
deronb1
in Electronics
Currently, I'm running an Onkyo SR 805 with a Marantz NA 7004. Love both pieces, but both are older. Have a 2TB HD full of FLAC files hooked into the Marantz and it works great with exceptional sound quality.
I am looking however to either replacing the Onk or the Marantz so I can control the files on the HD with a remote app. Right now it takes some time to navigate all the files through the Marantz. Can anyone recommend an AVR or Network player that they are using in a similar fashion? Speakers are 8 ohm bookies, easy to drive.
Will a Sonos Connect help?
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
Cheers
Not sure. If I can plug my external HD into it, maybe.
