Amp recommendations for SDA SRS?
Due to an insurance claim, I have approx $7000 to spend on a power amp(s) for my beautiful original SDA SRSs which I bought in 1987. If I don't use the full $7k, I lose half of it. I live in Europe and would prefer a 230v amp. I don't mind slightly used either. Does anyone have any common ground amp suggestions?
Thank you kindly,
Heater
    F1nut Posts: 49,799
    Can you not replace your previous amp with the same? I understand why you are asking about this on the Polk forum, but I think you'd get better suggestions from others in Europe due to the voltage issue.
  • Heater
    Heater Posts: 2
    Thank you sir. I will ask around locally. I don't know if my 29 yr old Yamaha MX-1000 and NAD 2200 are common ground. I am completely ignorant on the electronics involved and how to find out if they are common ground. I just like good stereo...
    F1nut Posts: 49,799
    The best way is to use a volt/ohm meter between the negative outputs (binding posts). If the ohm reading is zero or slightly above it's a common ground amp.
